Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-05-2004, 10:03 PM   #1
thealf
CF Senior Member
Send a message via ICQ to thealf
Default installed LGM longtubes, getting 135 and 300
im in a 2004 Z06, got the LG Longtubes installed, using the front O2 sensors for the fronts (not the rear sensors, like on the 2003s), got left going to left, right going to right (not crossed, like original), and now im getting the P0135, and the P0300.
135 is bank 1, sensor 1....front sensor, drivers side...
checked the OXY SEN fuse....its ok...
ive been messing with this since january, and have NEVER gotten my CEL to stay off...sent the PCM in to lou for LS1EDIT THREE SEPERATE TIMES, but im still having problems.
anyone got any ideas?
thealf is offline   Reply With Quote
Old 07-06-2004, 09:54 AM   #2
rwj383
CF Senior Member
rwj383's Avatar
Default Re: installed LGM longtubes, getting 135 and 300 (thealf)
P0135 is O2 heater circuit B1S1
P0300 is misfire detected
There is nothing wrong with your PCM. If you're sending it to LGM due to these codes, you're wasting shipping $$.
You need to run a scan and record a datalog of a few sensors to see what is up with these codes. For the O2 sensor, you'll want to watch to see if it is sufficiently switching and operating correctly. Likely you will find all is well, so possibly you pinched a heater wire or the O2 is not grounded well. Try to tighten it a little more in the header O2 bung.
For the misfire you will want to view misfire per cyl to see if you actually have a real misfire event. If just random misfires throughout, you will need to desensitize your misfire detection in the PCM.
Robert http://www.gen3motorsports.com
rwj383 is offline   Reply With Quote
Old 07-07-2004, 12:05 AM   #3
nuke61
CF Senior Member
Default Re: installed LGM longtubes, getting 135 and 300 (rwj383)
Question... did you use a copper or nickel based anti-sieze when you put in the O2 sensors?
nuke61 is offline   Reply With Quote
Old 07-07-2004, 12:08 AM   #4
thealf
CF Senior Member
Default Re: installed LGM longtubes, getting 135 and 300 (nuke61)
now that is something i dont know...what would a copper or nickel based anti seize do for me?
Old 07-07-2004, 04:45 AM   #5
rwj383
CF Senior Member
rwj383's Avatar
Using standard anti-seize on our O2 sensors can act like a dielectric or an insulator and keep the chassis of the sensor from properly grounding to the headers. So, a more conductive anti-seize with Cu or Ni in it would affect a good path to the header.
Robert
Reload this Page installed LGM longtubes, getting 135 and 300
Tags
heater, long, o2, tubes
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
