Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-04-2004, 11:00 PM   #1
wango tango
CF Senior Member
wango tango's Avatar
Send a message via AIM to wango tango
Default new tune after lifter install?!
Hey Guys, my car idles very fast (2k) until a few seconds after it comes to a stop. Here is some hisory of car...
1.5 month ago, car is fine. I beat on it some, notice a strange tapping noise, and car idles fast. Pull heads, put comp-r lifters in, noise gone, car runs great. NO high idle.
2 weeks later, I have another tapping noise. Pull heads, put regular comp lifters in. I fired it up, and it idles VERY high. I did initially have a hose disconnected. I unplugged pcm and it still has the high idle speed! It is intermittent too, although it mostly revs high as opposed to down low.
Your help would be greatly appreciated.
wango tango is offline   Reply With Quote
Old 07-05-2004, 11:30 AM   #2
L.Lopez
CF Senior Member
L.Lopez's Avatar
Default Re: new tune after lifter install?! (wango tango)
Did you check for a vacuum leak around the intake?Sometimes it's a good idea to replace the intake gaskets because they get to flat and don't seal correctly.
Good Luck!!!
:flag
L.Lopez is offline   Reply With Quote
Old 07-05-2004, 01:32 PM   #3
wango tango
CF Senior Member
Default Re: new tune after lifter install?! (L.Lopez)
i've yet to have an intake gasket, they seem pretty sturdy. i have an 01.
also, it doesn't idle high when the car is stationary. only when i'm moving...
i did idle relearn. we'll see if that helps. i dont think it will
Reload this Page new tune after lifter install?!
Tags
c5, install, lifter, lifters, z06
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C6 Z06 Frequently Asked Questions(FAQ) LTC Z06 C6 Z06 Discussion 56 08-02-2011 03:23 PM
Reassembling motor today , advice etc? steve40th C4 Tech/Performance 24 04-05-2005 09:06 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
