Howdy Josh!
In HPT (V1.3 I assume), the AC on/off control is the EDIT menu, SYSTEM item, then select the AC tab. You can set the re-enable/disable right and like the poster above said, it's an RPM setting.
FYI, the stock settings on my '03 Z06 are: Disable @ 4895 and Re-enable @ 4545
That 4895 is right where the LS6 cam really starts working, so I guess they figure you're doing some "business" at that point, heheheh.
Oh yeah, there's also a TPS setting for fan control which I suppose works in conjuction with the RPM settings (?) It's RE-enable @ 0% TPS, and DIS-able @ 100% TPS.
So is look like it disables at 4895 RPM _or_ anytime you go WOT - then when you get off WOT, and the RPM drops under 4545 (unless you go WOT and just let off the gas completely, which would drop your TPS to 0% and re-engage it? Not sure about that though
FWIW, I'll be leaving that alone on my ride - just the man said, you might not want to be spinning your compressor @ 6000+ RPM. I know when I had my RPM raised on my LT1 car, and I had the pretty new PS Pump fail on track, then I got the under-drive pulley for the AC and put like 10 events on the car with no problems - YMMV
