Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-30-2004, 05:27 PM   #1
rbrown7
Junior Member
rbrown7's Avatar
Default DTC c1282
Anybody have any experience for the yaw sensor calibration c1282 code?
Code will set anytime I run the car at the drag strip. Dealer is stumped. They went through the diagnostic tree and couldn't find a problem. Maybe I need to find another dealer.
-- Rick
02 Z06
rbrown7 is offline   Reply With Quote
Old 07-01-2004, 07:00 PM   #2
mapman
CF Senior Member
Default Re: DTC c1282 (rbrown7)
-- Rick
02 Z06
Any other DTCs being set? (e.g. C1281 or C1284)
Any modifications done to the car that might have moved (changed the location or orientation of) the yaw rate sensor?
There may be 2 additional characters displayed on a scan tool after the C1282 code. Did the dealer identify any additional characters? Those characters are engineering aids that are used to determine the specific criteria which caused to DTC to set.
mapman is offline   Reply With Quote
Old 07-02-2004, 04:17 AM   #3
rbrown7
Junior Member
rbrown7's Avatar
Default Re: DTC c1282 (mapman)
Thanks. Car is stock except for a LoJack. The thought occurred to me that it's mouting might have done something to the yaw sensor mounting. AH works fine. No other codes set. It's only when I run up through the gears hard that I get the c1282. Looking in the shop manual it looks like I have to pull the console to get the IP cover off to have a look at the sensor. I also see the manual the reference to the 2 digit "engineering aid" but I don't see a decoder ring as to what this subcode means.
All the dealer wrote up was "Found history code 1282. Performed diagnostic chart for code. Parameters are all within specified ranges". Is there a way I can pull the engineering code through the DIC or do I need a scanner? Is there a list of what the engineering codes for this DTC mean? Thanks!
== Rick
Old 07-02-2004, 05:43 AM   #4
mapman
CF Senior Member
== Rick
I don't find a "decoder ring" for these codes either. You do need a scanner to read them.
If the yaw sensor is out of place, it might be reading your rapid acceleration as a change in direction - when you do resolve the problem post what it was.
Sorry not any help.
Old 09-05-2004, 05:23 PM   #5
rbrown7
Junior Member
rbrown7's Avatar
Ok. Dealer found and fixed the problem. Said after conferring with the 'factory' they found a bracket missing that supports the yaw sensor. Referred to it as a "pencil bracket". I don't see anything in the shop manual that shows a part like this and there's no reference to it in the yaw sensor R&R section. Dealer also said that the bracket was left off from the factory but I believe it's possible that it was left off as part of a LoJack installation by a different dealer. Anyway, not DTC c1282 under hard accel anymore. Cool.
-- Rick
Reload this Page DTC c1282
Tags
2000, c1282, c5, corvette, dtc
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
two new codes on my 97 vette. anybody know? mvvette97 C5 Tech 24 09-11-2005 02:28 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
