Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-27-2004, 05:25 PM   #1
Mike Mercury
CF Senior Member
Mike Mercury's Avatar
Default here are my AFR graphs from Innovate; opinions wanted
From my new Innovate LM-1 AFR meter (thanks to Phil).
These were short runs:
WOT started at the 6 second mark:
and:
looks like I'm rich ???
Mike Mercury is offline   Reply With Quote
Old 06-27-2004, 07:37 PM   #2
gojo
CF Senior Member
gojo's Avatar
Default Re: here are my AFR graphs from Innovate; opinions wanted (Mike Mercury)
Mike,
It does look rich. You have an A4 right? You should do your WOT runs in 3rd gear as you would on a dyno. If these are not in 3rd I'd be curious to see a comparison.
Nice clean graphs with that setup.
gojo is offline   Reply With Quote
Old 06-27-2004, 08:47 PM   #3
itsonlyairandfuel
CF Senior Member
itsonlyairandfuel's Avatar
What are your factory O2 sensors reading at these levels?
itsonlyairandfuel is offline   Reply With Quote
Old 06-27-2004, 11:41 PM   #4
Mike Mercury
CF Senior Member
Default Re: here are my AFR graphs from Innovate; opinions wanted (itsonlyairandfuel)
I don't have a clue. I've ignored the factory sensors since they're not wideband anyways.
Old 06-28-2004, 01:43 PM   #5
Automag928
CF Senior Member
Automag928's Avatar
Send a message via AIM to Automag928
Were these runs on the street or dyno (if dyno - which one?) A dynojet doesnt put the load on a car like a mustang dyno or running on the street would. If you ran that on the street you are defintely runnin a tad rich. I'd feel comfortable with 12.5-12.6:1 but nothing past that. Not worth the few extra HP you would get to lean it out more IMHO...
Automag928 is offline   Reply With Quote
Old 06-28-2004, 02:24 PM   #6
Umrswimr
CF Senior Member
St. Jude Donor '05
Umrswimr's Avatar
Location: Overwhelmed as one would be, placed in my position.... DFW, TX
Send a message via AIM to Umrswimr
Is the second one AFR vs RPM or time?
Either way, I'd say you were a little on the rich side. AFAIK, most people tend to tune for 12.8 at WOT.
Umrswimr is offline   Reply With Quote
Old 06-28-2004, 03:04 PM   #7
Mike Mercury
CF Senior Member
Default Re: here are my AFR graphs from Innovate; opinions wanted (Umrswimr)
these are on-the-street runs.
The graph is capable of showing RPM, but I don't have the RPM input to the LM-1 unit... yet. SO right now it shows AFR only - over a period of time
Old 06-28-2004, 07:48 PM   #8
MrEracer
CF Senior Member
There are several things that you could do to improve your tune. I assume your fuel trims are near zero. If not, adjust IFR until they are. Then reduce your PE above the torque peak (pull fuel) until the graph is flat from min. to max. rpm. Once AFR is flat, reduce PE across the full rpm band to raise the AFR to 13:1 (street data, third gear, 3000 rpm to rev limit). This will give you the best power for your set-up. Good luck.
Shirl
SDRE
MrEracer is offline   Reply With Quote
Old 06-28-2004, 08:27 PM   #9
Mike Mercury
CF Senior Member
Default Re: here are my AFR graphs from Innovate; opinions wanted (MrEracer)
WOW; great specific info Mr. Eracer.
Sadly, my Predator programmer will only adjust AFR during WOT - using a fixed curve. But, I'm not an avid racer, so the Predator should give me the averages that I want.
When I can get time to altering the AFR, I'll log more runs and post the newer graphs.
Reload this Page here are my AFR graphs from Innovate; opinions wanted
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
