Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-25-2004, 09:05 AM   #1
Mopar Jimmy
CF Senior Member
St. Jude Donor '06
Mopar Jimmy's Avatar
Location: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
Default Do i need to be concerned with pcm (tranny code) 0705?
ANY info here would be greatly appreciated. Do i have to remedy this code if the tranny works fine (as it does) and what is the significance here? I never really threw this code until I had to downsize my gear from 3.73 to 3.42 (after recently) breaking the rear end diff housing on my old Getrag 3.73s!!
What is this code all about and what happpens (if anything) if i simply ignore it, etc.
Mopar Jimmy is offline   Reply With Quote
Old 06-25-2004, 09:42 AM   #2
ToplessTexan
CF Senior Member
Cruise-In II Veteran
ToplessTexan's Avatar
Default Re: Do i need to be concerned with pcm (tranny code) 0705? (MTI 427 Roadster)
It's a code that indicates something amiss with the park, neutral position, and backup switch which includes a range selector switch. That state of the switch positions should agree with the way you position the gear shift, P, R, N, OD, 3, 2, or 1. The code sets when the switch is in a state that doesn't indicate one of those positions. This could mean a misadjusted shift cable/lever, a failed switch, a damaged circuit or circuit component, or even just a poor connection somewhere in the circuits in question. The freeze frame data stored when the code set might or might not have information as to what state the 4 inputs in question were, I don't know. If it does that might give you someplace to start looking. Has it been doing this since you swapped gears? If it has (and even if it hasn't) I'd trot it right back to the shop.
ToplessTexan is offline   Reply With Quote
Old 06-25-2004, 03:42 PM   #3
Mopar Jimmy
CF Senior Member
St. Jude Donor '06
Default Re: Do i need to be concerned with pcm (ToplessTexan)
Thanks for your reply! If i don't address this what is the most likely consequence, if any, of ignoring same?
Old 06-25-2004, 07:38 PM   #4
ToplessTexan
CF Senior Member
Default Re: Do i need to be concerned with pcm (MTI 427 Roadster)
The PCM will be unhappy about what position it thinks the selector is in. I've no idea what the behavior would be. In my case the consequence would be that I would be highly annoyed, regardless of any other observable change in behavior, and would get it fixed. My bet is it's something simple.
Reload this Page Do i need to be concerned with pcm (tranny code) 0705?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Direct Port Dissaster! bruce1 C5 Forced Induction/Nitrous 78 05-27-2003 12:41 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
