Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-24-2004, 03:23 PM   #1
Erra
CF Member
Erra's Avatar
Default Going from 3:15 to 3.42. Reprogramming needed?
I'm a little confused. What does this message mean?
I've always heard that you must reprogram, when changing rear end gear
on a A4.
Please help me out
Erra is offline   Reply With Quote
Old 06-24-2004, 07:23 PM   #2
gojo
CF Senior Member
gojo's Avatar
Default Re: Going from 3:15 to 3.42. Reprogramming needed? (Erra)
The Rescale for a Corvette is not for the speedometer. Changing gears does not affect the speedometer. Scaling will make adjustments to the shift points. You may want to make further adjustments to your liking. Wait until you drive for a while to decide that. The important change done by scaling is to set the proper number of pulses expected. If scaling is not done the the PCM will think the trans is slipping and put you in safe mode.
gojo is offline   Reply With Quote
Old 06-24-2004, 07:46 PM   #3
Erra
CF Member
Erra's Avatar
Default Re: Going from 3:15 to 3.42. Reprogramming needed? (gojo)
Thanks gojo,
That will clear up my gear ratio problem.
Old 06-24-2004, 08:50 PM   #4
lar66BB
CF Senior Member
lar66BB's Avatar
The problem you may encounter is hiting the rev limit before it poopies at
wot. All you can do is try it you may be ok without programming.
lar66BB is offline   Reply With Quote
Old 06-25-2004, 12:54 AM   #5
Mike Mercury
CF Senior Member
Mike Mercury's Avatar
Default Re: Going from 3:15 to 3.42. Reprogramming needed? (lar66BB)
on a A4.
yes, but for many reasons EXCEPT for speedo error (which there isn't any).
Mike Mercury is offline   Reply With Quote
Old 06-26-2004, 03:37 AM   #6
0rion
CF Senior Member
Default Re: Going from 3:15 to 3.42. Reprogramming needed? (Mike Mercury)
Hey Mike, where at in Ohio?
0rion is offline   Reply With Quote
Old 06-26-2004, 04:57 PM   #7
Mike Mercury
CF Senior Member
Default Re: Going from 3:15 to 3.42. Reprogramming needed? (0rion)
about 15 miles east of Dayton.
[Modified by Mike Mercury, 3:59 PM 6/26/2004]
Reload this Page Going from 3:15 to 3.42. Reprogramming needed?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
A-4 trans replaced and still problems... CAracer C5 Tech 47 06-14-2003 11:53 PM
Bang for the buck Mods? NotSlo C4 Tech/Performance 11 11-23-2001 01:19 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
