Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-16-2004, 08:06 AM   #1
Tool Time
Junior Member
Tool Time's Avatar
Default Recommended Shift Points for A4 3:15 Using Predator
Has anyone done any extreme modification to their shifting? Thus far I have subtracted only 15% on shift time and added 5% on firmness. I have not made any changes to the shift points. Driving the Autobahn is pretty fun so I want to take advantage of the Predator programability.
Tool Time is offline   Reply With Quote
Old 06-16-2004, 12:16 PM   #2
Mike Mercury
CF Senior Member
Mike Mercury's Avatar
Default Re: Recommended Shift Points for A4 3:15 Using Predator (Tool Time)
for WOT shift point setting; place your A4 in "1" and accelerate to 6000 rpm - note the MPH.
Set your Predator 1 to 2 WOT shift point to about 2mph below what you noted.
Do the same in "2" for the 2 to 3 shift parameter... and (if you're brave enough) "3" for the 3 to 4,
then set your rev limiter to 6200 rpm.
This will get you to a good starting point.
[Modified by Mike Mercury, 1:15 PM 6/16/2004]
Mike Mercury is offline   Reply With Quote
Reload this Page Recommended Shift Points for A4 3:15 Using Predator
Tags
315, a4, c5, corvette, points, preditor, shift, tune
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
