Quote:
I have a 99 A4 vert with a 3.42 diff installed a couple months ago. Shifting into 3rd is a bit abrupt and jerky. I'm slowly decreasing the shift pressure. Started at 0% change and now at -6% without any improvement. How much further should I go?
Also, should I change the shift duration time also or stick to one parameter at a time?
Thanks!
Not good at all. Have you thrown any codes? Did you ever get a check engine light? If you do, or if you did, then DO NOT just clear it out with the Predator.
Who did the initial programming following the gear swap?
Park the car until you can get it properly programmed by either a professional or someone who knows what they are doing. It is all too easy to destroy the 4L60E transmission in our cars within a matter of minutes. I have seen it.
The axle ratio has to be rescaled from 2.73 to 3.42. The WOT & PT Shift Points MPH have to be rescaled from 2.73 to 3.42. Was this done?
You need a good custom tune from whomever sold you the Predator.
[Modified by EB20003, 11:39 PM 6/15/2004]
