Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-15-2004, 09:55 PM   #1
Alchemy
Junior Member
Default 1998 C5 Mystery noise when accelerating.
There is a rather curious rattling sound that is audible whenever the vehicle accelerates. It seems to do this in all gears (manual 6spd) and is a metallic sort of a noise. We've lifted it, and looked all underneath the car and still can't manage to locate the source. It seems to do this when the car is under load. There are no fault codes, and no other symptoms other than the noise itself. Any ideas?
Alchemy is offline   Reply With Quote
Old 06-16-2004, 05:12 PM   #2
leaftye
CF Senior Member
Send a message via ICQ to leaftye Send a message via AIM to leaftye Send a message via Yahoo to leaftye
Default Re: 1998 C5 Mystery noise when accelerating. (Alchemy)
Have you done any mods? I believe the MAF descreen causes the car to run lean. Hopefully I'll know firsthand this weekend when I get to check it out with HPTuner.
leaftye is offline   Reply With Quote
Old 06-16-2004, 10:49 PM   #3
99 The Hard Way
CF Senior Member
99 The Hard Way's Avatar
Send a message via AIM to 99 The Hard Way
Sounds like it detonating. I got a bad tank of gas once in my 98, and every time I accelerated I got knock. Try some octane boost & run that tank out of gas & try Amoco or BP. Just an idea. Has this just started? Have you fueled up recently? Scott
99 The Hard Way is offline   Reply With Quote
Old 06-17-2004, 02:43 AM   #4
Nick Williams
CF Senior Member
Default Re: 1998 C5 Mystery noise when accelerating. (99 The Hard Way)
Could be the check valves in the air tubes going into the exhaust manifolds. Or possibly detonating.
Nick Williams is offline   Reply With Quote
Old 06-17-2004, 03:30 AM   #5
0rion
CF Senior Member
Does it sound like it's coming from the front, middle, or rear of the car?
0rion is offline   Reply With Quote
Old 06-17-2004, 04:53 AM   #6
Alchemy
Junior Member
Default Re: 1998 C5 Mystery noise when accelerating. (0rion)
Sometimes it seems as though it's coming from right in the middle, others more from right behind driver side of vehicle. When it was first noticed, it was from just rear of driver side of vehicle. It's sort of a 'clanking' sound.
Old 06-17-2004, 04:58 AM   #7
Alchemy
Junior Member
No, no recent fueling. Only use premium (doesn't mean you can't get a tank full of bad gas, though) Coincidentally, right around the discovery of the noise, the fuel gage began going haywire. Not sure if there's a relationship here. Doubtful, the sound sounds too much like something loose or hitting .. ::sigh::... you've all been great-I do ever so appreciate ANY and ALL input on this-
Old 06-17-2004, 05:04 AM   #8
Alchemy
Junior Member
Default Re: 1998 C5 Mystery noise when accelerating. (leaftye)
No mods recently.
Old 06-17-2004, 05:06 AM   #9
Alchemy
Junior Member
Default Re: 1998 C5 Mystery noise when accelerating. (Nick Williams)
Will do. It's not pinging-which would usually be the symptomatic of detonation issues or misfiring, if I am not mistaken.
Old 06-17-2004, 10:16 AM   #10
ToplessTexan
CF Senior Member
Cruise-In II Veteran
ToplessTexan's Avatar
Is there any correlation with either vehicle speed or engine speed? Your description makes it sound like it's torque sensitive.
FWIW worth I've been chasing my own vibration/noise issue off an on for a while now. Noticed the other day while under the car that at least one transmission line (A4 car) clamp under the drive tunnel closeout was not properly secured. Fiddling with them changed my sound/vibration. I'm not familiar with the stick setup but the closeout panel does hide whatever is under it...
BTW, the service manual has a decent section in it on noise identification/isolation. Sadly not everybody has a frequency analyzer handy but there's good info there to guide your thinking.
[Modified by ToplessTexan, 8:18 AM 6/17/2004]
ToplessTexan is offline   Reply With Quote
Old 06-17-2004, 11:23 AM   #11
Nick Williams
CF Senior Member
Sometimes the ring around the top of the rear o2 sensors will vibrate and make a noise. I chased that for a while after installing headers.
Old 06-17-2004, 12:17 PM   #12
leaftye
CF Senior Member
Maybe it's something else entirely. Try shaking the hood up and down while it's supposed to be latched. The bumpers aren't always adjusted right, and can produce a sound kinda like you're describing.
Old 06-17-2004, 01:50 PM   #13
0rion
CF Senior Member
Have you tried tapping on your cats and see if they're rattling? It sounds like an exhaust issue to me but without hearing it I'm just guessing.
Old 07-11-2004, 06:09 PM   #14
Dally
Junior Member
Dally's Avatar
is it through the entire rpm range... do you notice it more on a lower gear or rpm?
I think I have that too... car is getting tuned this thursday .. Ill ask this guy what he thinks... he should know .. he built a 7 sec LS1 67 camaro.
so... i'll let you know what he may think.
Dally is offline   Reply With Quote
Old 10-04-2004, 06:41 AM   #15
Alchemy
Junior Member
First off-THANK ALL OF YOU who posted in reply to my question. I CANNOT thank you enough, it was greatly appreciated. The least I could do was update you on the issue; quick update on the noise: the problem HAS been located and erradicated. In the torque tube, on the rear bearing assembly there are three bolts. Well, two were missing. One was located. The other was no longer recognizable as a bolt. It appears that the first one made it past the rear coupler and was 'rolling' around, hence the metallic rattling noise. The second bolt wasn't so lucky. It appears to have been caught up in the coupler, which proceeded to chew its own face. This explains the crescendo that the 'rattling' erupted into about two months ago. The coupler has been replaced, as have the bolts, etc. There's some pics that show the aftermath of it all..http://www.msnusers.com/C5TorqueTube...nw?albumlist=2
Sorry, I couldn't find a place to upload them to on here, and wasn't sure if it was really something appropriate to be uploading onto this site, so please excuse the link.
Thanks again!
-M.
Old 10-05-2004, 09:40 AM   #16
ToplessTexan
CF Senior Member
Thanks for the update!
Reload this Page 1998 C5 Mystery noise when accelerating.
Tags
98, accelerating, c5, check, corvette, engine, makes, mystery, noise, noisy, rattle, sound, squeal, valve, vibrating
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
