Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-05-2004, 12:35 PM   #1
rkeetle
CF Member
Default Help! Headlight retraction noise
The driver's side headlight grinds for several seconds after light is down.
Anyone know how to fix?
rkeetle is offline   Reply With Quote
Old 04-05-2004, 01:34 PM   #2
ghostmech
CF Senior Member
ghostmech's Avatar
Default Re: Help! Headlight retraction noise (rkeetle)
Yes......you've got an actuator going bad (nylon gear). The only way to fix it is to change actuator. As far as I know, no one makes a rebuild kit for these so the whols actuator has to be changed. Had to do the right one last year myself
ghostmech is offline   Reply With Quote
Old 04-05-2004, 03:24 PM   #3
rkeetle
CF Member
Thank you!
I will check it out!
Roger
Old 04-05-2004, 07:42 PM   #4
16Again
CF Senior Member
St. Jude Donor '07-'08-'09-'10-'11
16Again's Avatar
Call Rodney he has what you need. http://www.rodneydickman.com/retail.html
Inexpensive fairly easy repair.
Bob
16Again is online now   Reply With Quote
Old 04-08-2004, 08:19 PM   #5
2000droptop
CF Senior Member
St. Jude Donor '07
2000droptop's Avatar
Yes......you've got an actuator going bad (nylon gear). The only way to fix it is to change actuator. As far as I know, no one makes a rebuild kit for these so the whole actuator has to be changed. Had to do the left one last year myself.
I've had problems with every C3 and C5 headlight door I've owned.
I glad chevy got rid of them on the C6
[Modified by 2000droptop, 6:53 PM 4/8/2004]
2000droptop is offline   Reply With Quote
Old 04-09-2004, 09:55 PM   #6
16Again
CF Senior Member
16Again's Avatar
Default Re: Help! Headlight retraction noise (ghostmech)
The link i posted in the above post is for the AVAILABLE rebuild kit. No need to change the acuator.
Bob
Old 04-13-2004, 02:14 AM   #7
nmbis2k
CF Senior Member
I think that the C5 setup is similar to the C4, or maybe just the same. The big Vette parts catalog company who name I forget, figured out a $6 nylon gear fix. I did both my previous car (not C5) headlights with their directions and great results. Probably took 2 hours per side, and the instructions worked.
nmbis2k is offline   Reply With Quote
Reload this Page Help! Headlight retraction noise
Tags
c5, headlight, makes, noise, retraction
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
