Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-28-2004, 04:35 PM   #1
larrysb
CF Senior Member
larrysb's Avatar
Default Z06 H-pipe and code P0430
(duplicate post in C5 tech - I posted here because there are more scan and tune types here)
I put a low-mileage 2003 Z06 H-pipe on my 02 vert, mated to a Z06 ti muffler system. Other than that, all stock at about 12,000 miles.
Last night it threw a CEL with P0430 code for the second time in about 6-7 weeks. A bummer to be sure.
I'm just wondering if there's any thing that can set this code besides the cats? So far it's been 0430 both times. Maybe the rear o2 sensor on that bank (right I think, got to look up the code again to be sure)?
Otherwise I may need to put the 4-cat h-pipe back on.
larrysb is offline   Reply With Quote
Old 03-28-2004, 06:59 PM   #2
0rion
CF Senior Member
Default Re: Z06 H-pipe and code P0430 (larrysb)
Could be a bad O2 sensor although my bet is the cat on that side is bad. What's your gas mileage been like and do you have any accessive black soot in the exhaust on that side? A bad O2 will have those signs. Since you just did the H pipe make sure of your connections and whatnot to that sensor too. My bet would be the cat though. Do you have a-tap or efilive where you can look at the mv's to the O2's??? That will tell you if the sensor is bad too. Good luck.
0rion is offline   Reply With Quote
Old 03-30-2004, 04:25 AM   #3
larrysb
CF Senior Member
larrysb's Avatar
Thanks for the info. I don't have autotap or efi, so I'm shooting blind. I'm hoping it might be a marginal sensor. Maybe they got some anti-sieze or grease on it when transfering it from the original h-pipe. I took a good look around underneath the car, traced out the wiring and made sure the O2's were plugged in and tight. Of course, they were. I noticed the shop used some kind of high-temp orange stuff on the flange to the mufflers. Normally, the factory gasket goes on dry between the mufflers and pipes. Could be some silicone poisoning? I dunno, probably wishful thinking on my part.
Took my handy IR pyrometer and found both cats to be running identical temperatures, which might be taken as a good sign. No sign of soot or fuel smells.
Maybe I'll try a new rear O2 sensor for grins.
Old 04-27-2004, 09:41 AM   #4
Allthrottleandsomebottle
Race Moderator Moderator
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Support Corvetteforum!
Allthrottleandsomebottle's Avatar
I just had our 2000 start throwing the same code on the PS side..........all is tight and its an FLP sytem with their hi-flow cats..........only 12K miles on them. Cats are also the same temps! I think rear O2 sensor.........of course I told, Julie my wife I can fix it by putting in the straight pipes, and O2 sims......
Allthrottleandsomebottle is offline   Reply With Quote
Old 05-05-2004, 03:10 PM   #5
TT_Vert
CF Senior Member
Send a message via AIM to TT_Vert
Default Re: Z06 H-pipe and code P0430 (ALLTHROTTLE&NOBOTTLE)
id like to know what you guys find out. im having the same problem : http://forums.corvetteforum.com/zero...&id=1547229555
TT_Vert is offline   Reply With Quote
Reload this Page Z06 H-pipe and code P0430
Tags
c5, code, corvette, diagnostic, larrysb, p0430, stock, throws
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
