Aprrox. Horssepower based on MAF reading?
Is there a general rule of thumb for guessing how much horsepower you are making based on MAF readings? Thanks.
Re: Aprrox. Horssepower based on MAF reading? (sbrown99ta)
The nominal fuel consumption is 0.5 lb per hour per HP (brake specific fuel consumption, bsfc). An estimate of the maximum power available from a set of injectors is to multiply an injector's rating in lb/hr by 8 (#of cylinders) and then divide by 0.5. For example, 24 lb/hr injectors should be good for 24*8/0.5 = 384 HP.
For max power, we want an AFR of something like 13.5:1. So that means we need 13.5*.5 = 6.75 lb/hr per HP. EFILive measures MAF in lb/min, so we want 6.75/60 = .1125 lb/min per HP.
So to get approximate HP, take the MAF reading in lb/min and divide by .1125. For example, MAF of 25 lb/min divided by .1125 = 222 HP.
-Jim
:auto:
-Jim
:auto:
I multiply MAF lbs/min by 10 and use that only to judge changes. It's not accurate, just somewhat directional..
(((MAF * 3600)/453.6)/known AFR)/BSFC
This simplified is
(7.9365 * MAF) / (AFR * BSFC)
On my 427 (506 RWHP) the peak MAF was 384 g/s. Using
a BSFC of 0.45 and the W/B AFR of 13.2:1...this formula yielded 513
(7.9365 * 384) / (13.2 * 0.45) = 513
[Modified by '97 C5, 9:22 PM 12/29/2003]
Re: Aprrox. Horssepower based on MAF reading? ('97 C5)
So, if I'm following this correctly, if we max out the MAF (454gms/sec) at 5200rpm, that means we should be making in the ballpark of 530rwhp at that RPM? Does that sound right?
Based on '97 C5's calculations:
"On my 427 (506 RWHP) the peak MAF was 384 g/s. Using
a BSFC of 0.45 and the W/B AFR of 13.2:1...this formula yielded 513 "
If we convert 384 g/s to lb/min:
(384/453.6) * 60 = 50.8 lb/min
Multiplying by 10 gives 508 HP, which is pretty close to the formula's result of 513 HP.
So gojo is right on the mark.
:yesnod:
:yesnod:
Re: Aprrox. Horssepower based on MAF reading? (sunvet)
You can log Lb/Min with EFI which makes it easy to quickly see the results of tuning changes. I don't know about other scanners.
