Catalytic Converter OverTemp Table
Per the LS1Edit manual, "This table has the estimated Catalyst temperature to go into the 4 Cat cooling modes."
I didn't notice a temp sensor that I could track with AutoTap, did I miss it? If the temp does reach these levels, what happens?
Re: Catalytic Converter OverTemp Table (TooManyIDs)
There is no actual sensor, its estimated based on other conditions. I dont know about autotap, but EFILive Pro can read this value. If you exceed the temps in that table, the pcm will automaticly add extra fuel.
If you have no cats, you can simply disable the COT mode.
Eric
Eric
Re: Catalytic Converter OverTemp Table (66ImpalaLT1)
Eric,
What kind of "estimated" values are you seeing? Are they getting anywhere near the 830°C threshold?
[Modified by TooManyIDs, 9:22 PM 9/15/2002]
I havent checked. I just got EFILive Pro on friday, but the car was disabled until just a few hours ago.
Eric
Eric
Re: Catalytic Converter OverTemp Table (Face)
Face,
I assume you mean with LS1Edit.
Screen before the one pictured above, has a check box. Go to Engine Calibration, then select the "Test Parameters" tab.
Face,
Thank you!
[Modified by Face, 11:46 AM 9/16/2002]
So far according to EFIlive my calculated cat temp (I have no idea how they calculate it) hasnt reached 700 degrees yet. COT looks like it kicks in at 750 degrees or so. I'll check my next time on the dyno and see how high the temp goes. I also noticed that the 1st threshold for f-bodies is 40 degrees less then a C5 (99-00 anyhow) so thats why more f-body guys may be seeing overtemp kick in, especially if you start leaning it with a MAFT ot edit.
Oddly enough the 3rd and 4th threshold temps are quite a bit hotter on an F-body then a C5 so who knows. I'm not sure what the threshhold has to do with the actual mixture though..
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Re: Catalytic Converter OverTemp Table (kp)
Remember to disable the COT if you have removed your cats or it will greatly richen your car at 5500rpm and no matter how much you play with the PE vs RPM table you will not be able to get rid of how rich it makes your car run.. You would lose an easy 10-15rwhp at peak HP RPM range if this COT kicks in.
Re: Catalytic Converter OverTemp Table (6Speeder)
As per the manual "4 cat". Does this mean that only those cars with pre-cats have this programming? Yes, I am grasping at straws. I'd rather not deal with it. :cool:
Re: Catalytic Converter OverTemp Table (MattG)
[QUOTE]Remember to disable the COT if you have removed your cats or it will greatly richen your car at 5500rpm and no matter how much you play with the PE vs RPM table you will not be able to get rid of how rich it makes your car run.. You would lose an easy 10-15rwhp at peak HP RPM range if this COT kicks in.
[/QUOTE
Well my LS1-Edit is here!!!!
COTS is the 1st thing to go.
Matt I have Gutted CATS and 02 Sims.. But you say that the extra fuel comes in at 5500rpm...I assume the 02 sensors have nothing to do with the overtemp condition and they are only for emisisons..
So I guess I can count on an extra 15 ponies after 5000rpm?
[/QUOTE
Re: Catalytic Converter OverTemp Table (chuckster)
Just an update on what I stated (I dont like to give bad info on a forum), I dont know what I was looking at a few weeks ago but it appears that the calculated cat temp is not a valid parameter on a 99 C5. It shows up on the list but it says it isnt supprted by my PCM. I was working with a 2001 a few weeks ago and I think it may have been valid on that car (I know I seen 700 degrees somewhere). I was going to get some readings today and it came up as not available on my car according to EFIlive on my car.
I am not sure if the COT even applies to a 99 49 state car since its not mentioned anywhere in the service manual and the parameter isnt supported by the scan tool. Back to square one for me trying to figure out how the PCM calculates cat temp...
John,
YOu are right, THe PCM does not measure the CAT temperature, It
predicts it based on engine load, RPM, and time.
Ken
Team ZR-1 wrote:
> Since the C5 does not support this COT function with 3way Cats,
> there is no sensor as other Cats have to measure the internal temperture and
> GM OBD-II does not support COT PID
> then how does this table function since its contents has nothing to compare to ?
> JR
> Team ZR-1 Consulting Services
kp,
Any more news?
Any more news?
Only two cats on my car (it comes that way) and I haven't touched the O2 sensors.
I've done a lot of pulls. The drop I saw, on the last two pulls only, was from around 12.6:1 at 6,000rpm to about 11.6:1 at 6,400rpm.
It was sudden. Have never seen this before, don't believe it's the PE tables. My table values aren't going richer in either PE table.
[Modified by TooManyIDs, 8:36 AM 9/26/2002]
