Would it be safe to allow my torque converter to lock up during shifts??
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
Re: Would it be safe to allow my torque converter to lock up during shifts?? (joe2gaan)
No, if it's locked you can not shift.
Re: Would it be safe to allow my torque converter to lock up during shifts?? (Godspeed)
Several automatics (Ford is one) do not unlock the torque converter when shifting in the upper gears. Automatics have planetary gear sets so interrupting engine power is not necessary during gear changes. Only bands and clutches are needed to effect change gear ratios. Caveates are torque converter clutch capacity and drive train shock loads.
