C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Log of 2nd Gear Pull with DiabloSport Tune C5 Z06
Old 08-21-2014, 11:08 PM
2001c5z06
8th Gear
2001c5z06's Avatar
Default Log of 2nd Gear Pull with DiabloSport Tune C5 Z06
2001 c5 z06 2nd gear pull hear is the graph, can anyone let me know if that looks good. Knock stayed 0 this pull but on another run bumped as high as 2.
Any insight would be much appreciated.
Old 08-22-2014, 12:15 PM
aaronc7
aaronc7's Avatar
This datalog is pretty useless, the Y axis scaling doesn't tell you anything.
Fuel trims look pretty good
What is your peak timing at wide open throttle/high rpm?
Old 08-22-2014, 01:20 PM
2001c5z06
8th Gear
2001c5z06's Avatar
Hey thanks for the reply! This was at WOT but I do not know the peak timing since this is just the Performance Program that comes on the diablosport device I have not tweaked anything myself.
I am not familiar with data logging/tuning so if you have advice on what I should log and display I would happy to take more data and repost with better graphs.
Old 08-22-2014, 02:25 PM
aaronc7
aaronc7's Avatar
I'm not familiar with that program so I can't really help ya there. If there's a way to export the data to excel, you could upload that (.csv is a common format/extension).
Most datalogging software programs have a way to select a "column" of data to display at a given time. See in the upper right hand corner of the screen.... it's showing all data for those parameters at time 0:00:00.000.
Find where you went WOT in the log and see how timing and other parameters change thru the rev range. For example the stock tune will usually run 22* of timing above 4000 RPM at WOT. I can see timing ramping up and then flatling at the end of the datalog, but there's no way to tell what the actual values are based on the pic you posted.
Old 08-22-2014, 06:56 PM
2001c5z06
8th Gear
2001c5z06's Avatar
At 4000 rpm 24.5 degrees spark advance at 4400 rpm 23 degrees and then 22 or 22.5 to redline
Old 08-22-2014, 08:00 PM
aaronc7
aaronc7's Avatar
Sounds like it's a very conservative tune. I run around 27* max at WOT on 93 octane, only seen 1blip of 0.2 knock ever.
What octane gas you running?
Old 08-22-2014, 08:07 PM
tblu92
tblu92's Avatar
St. Jude Donor '13-'14-'15
Typically you want to data log in the gear that is 1:1 ratio-- If you log in a lower gear there is not enough load on the engine to accurately make adjustments to both fuel and spark--- In 2nd gear the AFR will be richer and the timing will not show any KR cause there is not enough load on the engine----On an Automatic for example 3rd gear is 1:1 so you would need to log it there----It becomes difficult because in 3rd at 6000 RPM's you are way over 100 MPH and it becomes a safety issue---Running a data log in 3nd gear on an automatic will show richer AFR's --can be about 3-5 tenths !! and you'll get no KR --so its not a good way to tune
PS: you will notice on dyno tunes they always look at the numbers in the gear that's 1:1---to be accurate
Old 08-22-2014, 10:28 PM
2001c5z06
8th Gear
2001c5z06's Avatar
I am in CA and only have 91 octane gas. I will run another log in the next few days in third gear and try to make a graph that is actually useful.
Old 08-23-2014, 11:02 AM
aaronc7
aaronc7's Avatar
True you want to dyno in gear closest to 1:1 ratio. For datalogging, it comes down to what you're able to do on the street. Higher gears work better as it takes longer to go thru the rev range with the datalogger recording stuff at a constant rate-- so you get more 'resolution'/more data points.
For full gear datalogs I try to get a 3rd gear pull in. 2nd isn't ideal, but obviously much easier and safer to get done on the street- better than nothing either way.
Old 08-23-2014, 04:07 PM
SVT_Z06
SVT_Z06's Avatar
Strange. Typically, timing is lower at peak tq, then it ramps up to redline.
How does it feel? Any mods?
Also, get a third gear log. That will provide better and more appropriate results for reviewing/critiquing.
As the others mentioned, see if you can export the .csv file and post it.
Old 08-24-2014, 10:49 PM
Supercharged111
Supercharged111's Avatar
Typical of GM, their timing always drops off the end of the earth as the motor approaches redline. Get a dyno tune and that'll never happen.
Old 08-26-2014, 07:07 PM
2001c5z06
8th Gear
2001c5z06's Avatar
I took a bunch more logs and they all look pretty much the same.
Diablo tune holds about 22 degrees of timing after 4k rpm
Stock tune holds about 20 degrees of timing after 4k rpm
Depending on each run whether stock or diablo it will pull 0 up to 2 degrees of timing, usually 0 or 1. I think this is based mostly just on heat and crappy gas.
Old 08-28-2014, 12:54 AM
2001c5z06
8th Gear
2001c5z06's Avatar
More logs that actually so the rpms climb...
Old 08-28-2014, 09:19 PM
2001c5z06
8th Gear
2001c5z06's Avatar
So based off old posts on the diablosport forums and using DSLogRedux I made some changes.
I started with -4 on injector slope (makes it richer) and -2 on fuel enrichment (leans out WOT). Still lean at cruising and have eventually moved myself to -6 on injector slope and -4 on fuel enrichment. I started logging AFR as well, although not extremely accurate it shows me holding 12.7 at WOT except for maybe a small rich bit in between shifts to 12 or 11.7.
ltft on long cruises is still a little positive so I may -1 or -2 more from injector slope and then tune fuel enrichment accordingly (prob -1)
What does everyone think of that? Once I get that squared away I will look into possibly bumping up timing. Although probably not much since I am on CA gas.
Old 08-28-2014, 09:24 PM
2001c5z06
8th Gear
2001c5z06's Avatar
With settings injector slope -6 and fuel enrichment -4 I took this cruising log around 2k rpms for a couple minutes. Here are the ltft and what dslogredux suggests.
To Log of 2nd Gear Pull with DiabloSport Tune C5 Z06
Quick Reply: Log of 2nd Gear Pull with DiabloSport Tune C5 Z06
