P0030 x2
P0030 x2
Here is the story. 2002 c5 6spd. Xs power Lt's and exhuast. Haltech intake. (When installig the Lt's i had to replace the drivers a/f as the oem broke. I replaced it with a denso unit.)Got tuned by chuck cow literally right after i finished the install.Car ran great for 2 weeks(probably less than 150 miles) . Then the car threw a p0030. A/f bank 1 sensor 1. I change it out thinking maybe the new a/f was a bad unit. Clear the code run it for about 60 miles.( over the period of 2 weeks) light comes back on for same thing p0030 b1 s1. So now im a little dumbfounded. Is it possible the tune is lean and burning out that o2? Or maybe i need to use an oem unit? Or could it be another bad sensor( slim chance) any advice or ideas would be great.
St. Jude Donor '13-'14-'15
P0300 is a "random misfire "code Very common with LT's
1st find out if the code is in fact "REAL" or "FALSE"
On a real P0300 code you can hear or feel the misfire in the engine--
On a FALSE code the engine runs perfect but still throws the code
LT's create false misfire codes---Correctable with tuning by:
Turning OFF the misfire tests in the diagnostics part of your tune by maximizing or minimizing the Parameters AND Maxing out the individual misfire tables
