Trans tune trouble wont shift 6600 on drive
We just tune my car after my cam spring head upgrade
We setup the mph and the shift to 6600
The car will go at 6600 if i put the gear on 1,2,3,4
On drive, the car shift at 6200
I know the mph should be reach before the mph
But it still dosent work
We lower the mph and same thing on drive
Need help on this one !!
St. Jude Donor '13-'14-'15
Doesn't make sense --so what does it do when in drive---shift at 6200 or just stay at 6200 and NOT shift ?
The MPH WOT shift points need to be set at the MPH at 1000 RPM's less---Called the "SHIFT SPLIT"--your software should tell you what MPH to input at 5600---- Also the Downshift WOT points need to be the same Send me your rear end ratio and your rear tire size and I can recc. where they need to be
You may have other issues like running out of fuel which can be checked by looking at your fuel pressure at WOT
17 inch on rear or 18 inch ??
Also You DO NOT make a speedo correction for a gear change on a Corvette---Only for a tire change-- If you did that would cause your speedo to be way off as well as all your shift points
let me know about the rear tire diameter 17 or 18 and I will send recc settings
