C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
HVAC codes ?
Old 06-18-2014, 09:43 PM
ZEEZERO-6
ZEEZERO-6's Avatar
Default HVAC codes ?
I hope this the right forum section. How come every time I run the diagnostic procedure on the DIC I have 2 to 4 HVAC codes. I reset them but they always come back ?
Should I just ignore them ?
Old 06-20-2014, 01:41 AM
tblu92
tblu92's Avatar
St. Jude Donor '13-'14-'15
Can you post the codes?? If any are "P"codes you must trace down the problem--
Old 06-20-2014, 10:33 AM
ZEEZERO-6
ZEEZERO-6's Avatar
I will try to write them down next time I check.
Old 06-23-2014, 04:38 PM
ZEEZERO-6
ZEEZERO-6's Avatar
OK Gents here are the codes = B0361 H & B0441 H C ?
I already know what the H & C stand for.
I Have been informed in the General C5 section that it's the relay #34 that needs replacing but how do I locate it and where do I purchase said relay (#34 relay) ?
Old 09-01-2014, 07:15 PM
SS2001SS
SS2001SS's Avatar
The 0441 code is for the driver's side actuator. Good starting point: https://www.corvetteforum.com/forums...actuators.html
Old 09-30-2014, 10:41 AM
mrr23
mrr23's Avatar
St. Jude Donor '15
I get those codes as well. My ac doors work just fine. So no worries for me.
To HVAC codes ?
Quick Reply: HVAC codes ?
