Weird issue Reduce Engine power + Security on my C5Z
Hey guys I need your help lately I've been getting a weird issue on my Z
while driving I get both the reduce engine power + Security on my dash and the Temp gauge goes to full + Oil Pressure gauge drop 0
The car drives normally no difference at all even at WOT no change.
Anyone got this issue before or know what's the cause?
Could it be bad PCM (Computer)?
Anything will be help.
Thanks in advance.
Sam.
Thanks in advance.
Sam.
St. Jude Donor '13-'14-'15
Many times in reduced power modes the gauges just act crazy read incorrectly or stuck on 0 The only way to diagnose the issue is to have someone read the codes--even if there is no check engine lite I'm sure some are stuck In there--MostAutozones or O-Riellys will read codes for free--write them down and report back--does not sound like any thing major---but sounds like you have an obviously modded eng and you are getting "false codes"---list all your mods--tire size changes gear changes eng chaanges
