97 ECM swap to 0411 Fuel guage settings??
I just swapped my 97 to an 0411 with a 2001 OS. Need to know what settings people have successfully used for the fuel gauge tables.
When I first installed it, the gauge read EMPTY after filling the tank. I found out by searching google that one of the 5 volt pins needed eliminated and that got it working.
The only problem now is that the gauge reads 7/8ths full when the tank is completely full. Other than that seems to work fine.
That's what I did with mine too, but getting the 7/8ths tank instead of full. If you could check your settings that would be great. That will let me know if I need to start looking on the mechanical side rather than in the tune.
