2000 C5 - No IAT vs IFR Table In HPT - Solution?
Hello,
I have a 2000 C5. I'm was hoping to tune a dry nitrous setup through spinmonster's IAT tricker method as described here: http://forums.corvetteforum.com/c6-f...wet-shots.html
I do not have the IAT vs IFR table. Is there a way to get this table via updating the OS? Or is my only option to physically swap to a later model PCM?
Thank you!
Jack
Thank you!
Jack
Keep your stock operating system. You can't just swap OS without also re-working or replacing your wiring harness.
There are ways to use IAT to trigger less ignition advance and ways to bump AFR with your existing ECM. Just what exactly are you wanting to accomplish?
My new idea is to use the ECT sensor to accomplish the same goal. Just tune every parameter that uses ECT for my nitrous tune at a false 284*
Jack
Bump. Anyone have experience running an 01 or 02 OS on '00 hardware? will that get me where i need to be or do I need to do the full PCM swap?
Also, if anyone sees any reason that the ECT method will not work, please let me know.
Jack
Jack
