C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
How to swap ECM on a C5 (ECU)
Old 05-23-2014, 07:17 AM
elerico
elerico's Avatar
Default How to swap ECM on a C5 (ECU)
my ecu is tuner lock
i just bought a similar ecu from a chevy astro with the same code
what's the procedure to swap the ecu with my vin...
i cant find nothing on the web
Old 05-23-2014, 01:16 PM
Rookieracer
Support Corvetteforum!
Rookieracer's Avatar
You will need to flash in the correct tune for your car using EFILive or HP tuners. Either software can rewrite the VIN # as well. I would probably set the "Vehicle Anti Theft" setting to disable just to make sure the ECM plays nice with all of the other modules.
Old 05-23-2014, 04:48 PM
78GEN3
78GEN3's Avatar
What year is your car and what is the hdwr number on the new ECM?
Old 07-04-2014, 03:03 AM
tblu92
tblu92's Avatar
St. Jude Donor '13-'14-'15
I think you are n for a nightmare with an Astrovan ECM I would try to at least get a ECM from a Camaro silverado
To How to swap ECM on a C5 (ECU)
Quick Reply: How to swap ECM on a C5 (ECU)
