C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
horses power come down
Old 04-23-2014, 11:03 AM
mohammedtuner
mohammedtuner's Avatar
Default horses power come down
hi
i have c5zo6 2001 the engine 408 i but te car on dyno jet befor two months i got 534 hp and 484 tq.
The weather was winter and cool air and the fuel rito was 12.9
until three days i but the car on dyno agian and i found the fuel rito 14.2 and horses come down to 507 hp note the summer is income heat .. after that i tune the car again and i get to 517 hp 464 tq ..
Note that the car is very excellent and I do all maintenance ..
is that normal or not ???
thank you
Old 04-23-2014, 02:13 PM
Horps27
Horps27's Avatar
Well governor...
Old 05-02-2014, 02:56 PM
78GEN3
78GEN3's Avatar
Originally Posted by Horps27
Well governor...
Old 05-03-2014, 02:12 AM
danieloneil01
danieloneil01's Avatar
Originally Posted by mohammedtuner
hi
I have a c5zo6 2001 with a 408, I put the car on a dynojet two months ago and it made 534 hp and 484 tq. It was winter with cool air and the air/fuel ratio was 12.9. Three days ago I put the car on the dyno again and the air/fuel ratio was 14.2 with 507 hp. After that I tuned the car again and I got 517 hp 464 tq. Note that the car is very excellent and I do all maintenance. Is that normal or not?
thank you
Same dyno? What was the AFR on the last set of numbers? Timing the same from the first and last dyno numbers?
Old 05-03-2014, 05:54 PM
danieloneil01
PS, cooler air = more power.
Old 05-14-2014, 03:47 PM
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
Need a lot more info, plus if it is colder weather out side number will be better if all other stuff is the same. Robert
Old 06-15-2014, 01:36 PM
RED99
RED99's Avatar
Different Dynos will result in different numbers, also same Dyno and different correction factor.
IAT (Air density) and Engine coolant temp will change timing which will result in different numbers itself. Going from winter to summer, the winter should show more HP for more dense air. But its all in how the tune makes adjustments for all these thousands of different factors.
Old 06-16-2014, 05:16 PM
Higgs Boson
Higgs Boson's Avatar
Received 2,379 Likes on 1,238 Posts
what color is it and where are you? I used to have a 2001 Z06 with a 408. :-)
Old 06-17-2014, 01:56 AM
rjwz28
rjwz28's Avatar
That would be awesome if all that difference was due purely to temp... see my sig for a combo that seriously dyno'd low for the sum of its parts
Old 06-20-2014, 02:14 AM
tblu92
tblu92's Avatar
St. Jude Donor '13-'14-'15
Differences in ambient air temps can make huge changes in RWHP--especially on a dyno where you have no driving air to cool the IAT sensor---The IAT sensor at apprx 131* will remove 5-7 degress of timing that's huge when you only have 27-24 to stsrt with---making your car lazy and rich NOT LEAN-----If t was a colder day on the second run then yes it could bceome lean
To sort out you need to get the data from the logger to see what's happening---Intake air temps--coolant temps---knock retard==without this info you are just chasing your tail and guessing as is your tuner--
A prpperly tuned LS will eliminate all those inconsistent timing decuctions--and make tuning not a procedure of timing but fuel----Less air density take some fuel out better air density add some fuel in ( PE table) this eliminates all the crazy false IAT temps from underhood heat soaked IAT sensors----
Old 06-20-2014, 08:07 AM
Higgs Boson
A properly tuned LS? 27 degrees to start with? Sounds like someone hasn't looked a 2014 calibration yet....
Old 06-22-2014, 01:35 AM
tblu92
tblu92's Avatar
You can't compare the timing on a port injected LS eng to the new 2014 SIDI engines--- It's a whole new ball game with SIDI engines--
Don't know what you are trying to say---But on a LS engine properly tuned by eliminating false timing deducts-- 24* is not out of range ---with race gas or 93 oct non Calif premium you can get 27* with no REAL knock retard
To horses power come down
Quick Reply: horses power come down
