horses power come down
hi
i have c5zo6 2001 the engine 408 i but te car on dyno jet befor two months i got 534 hp and 484 tq.
The weather was winter and cool air and the fuel rito was 12.9
until three days i but the car on dyno agian and i found the fuel rito 14.2 and horses come down to 507 hp note the summer is income heat .. after that i tune the car again and i get to 517 hp 464 tq ..
Note that the car is very excellent and I do all maintenance ..
is that normal or not ???
thank you
thank you
hi
I have a c5zo6 2001 with a 408, I put the car on a dynojet two months ago and it made 534 hp and 484 tq. It was winter with cool air and the air/fuel ratio was 12.9. Three days ago I put the car on the dyno again and the air/fuel ratio was 14.2 with 507 hp. After that I tuned the car again and I got 517 hp 464 tq. Note that the car is very excellent and I do all maintenance. Is that normal or not?
thank you
thank you
Received 1,762 Likes
Different Dynos will result in different numbers, also same Dyno and different correction factor.
IAT (Air density) and Engine coolant temp will change timing which will result in different numbers itself. Going from winter to summer, the winter should show more HP for more dense air. But its all in how the tune makes adjustments for all these thousands of different factors.
Received 2,379 Likes
what color is it and where are you? I used to have a 2001 Z06 with a 408. :-)
St. Jude Donor '13-'14-'15
Differences in ambient air temps can make huge changes in RWHP--especially on a dyno where you have no driving air to cool the IAT sensor---The IAT sensor at apprx 131* will remove 5-7 degress of timing that's huge when you only have 27-24 to stsrt with---making your car lazy and rich NOT LEAN-----If t was a colder day on the second run then yes it could bceome lean
To sort out you need to get the data from the logger to see what's happening---Intake air temps--coolant temps---knock retard==without this info you are just chasing your tail and guessing as is your tuner--
A prpperly tuned LS will eliminate all those inconsistent timing decuctions--and make tuning not a procedure of timing but fuel----Less air density take some fuel out better air density add some fuel in ( PE table) this eliminates all the crazy false IAT temps from underhood heat soaked IAT sensors----
You can't compare the timing on a port injected LS eng to the new 2014 SIDI engines--- It's a whole new ball game with SIDI engines--
Don't know what you are trying to say---But on a LS engine properly tuned by eliminating false timing deducts-- 24* is not out of range ---with race gas or 93 oct non Calif premium you can get 27* with no REAL knock retard
