tuners please look
tuners please look
any ideas if this is right or wrong car dies when i put it gear
list of mods
now the car idles around 980-1050 rpm and when i put the car in gearit dies, it will stay running if im at about 1400 rpm whith foot on brake and shift into gear but as soon as i lift from brake it dies
list of mods
forged pistons -rods
ported oil pump
timing chain
ms3 cam
prc227 heads
ported 90mm tb
fast102mm intake
stock mass air flow
1.72 rockers
ls7 lifters
fast fuel rails
42lb injectors
vararam cai
lt headers
rpm stage 6 trans--automatic
rpm stage 3 rear
342 gear
vig 3800 stall
sent computer to east coast supercharging for base tune,
2000 Chevrolet Corvette G = 5.7
I/M Monitors
Since DTCs Cleared
Misfire Monitor ok
Fuel System Mon ok
Comp Component ok
Catalyst Mon ok
Htd Catalyst n/a
Evap System Mon inc
Sec Air System inc
A/C Refrig Mon n/a
Oxygen Sens Mon inc
Oxygen Sens Htr ok
EGR/VVT Sys Mon n/a
DTCs (Codes)
P0103 ENG $10
Mass Or Volume Air Flow A Circuit High
Input
HISTORY CURRENT
Record Data
FRAME: 0 TM: 0.0
MIL STATUS Off
ABSLT TPS(%) 11.8
ENG SPEED(RPM) 987
CALC LOAD(%) 3.5
MAF(LB/M) 1.29
MAP("HG) 20.4
COOLANT(°F) 169
IAT(°F) 61
IGN ADV(°) 16.0
SECOND AIR ATMOS
ST FTRM1(%) 0.0
ST FTRM2(%) -2.3
LT FTRM1(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.240
ST FTRM11(%) 0.8
O2S12(V) 0.445
O2S21(V) 0.300
ST FTRM21(%) -3.1
O2S22(V) 0.445
OBD2 STAT CA
FRAME: 1 TM: 2.3
MIL STATUS Off
ABSLT TPS(%) 11.8
ENG SPEED(RPM) 988
CALC LOAD(%) 3.5
MAF(LB/M) 1.32
MAP("HG) 20.1
COOLANT(°F) 169
IAT(°F) 61
IGN ADV(°) 21.5
SECOND AIR ATMOS
ST FTRM1(%) 0.0
ST FTRM2(%) -1.6
LT FTRM1(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.435
ST FTRM11(%) -0.8
O2S12(V) 0.445
O2S21(V) 0.855
ST FTRM21(%) -2.3
O2S22(V) 0.445
OBD2 STAT CA
FRAME: 2 TM: 4.8
MIL STATUS Off
ABSLT TPS(%) 11.8
ENG SPEED(RPM) 1009
CALC LOAD(%) 3.1
MAF(LB/M) 1.29
MAP("HG) 20.1
COOLANT(°F) 169
IAT(°F) 59
IGN ADV(°) 18.0
SECOND AIR ATMOS
ST FTRM1(%) 0.0
ST FTRM2(%) -3.9
LT FTRM1(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.870
ST FTRM11(%) 1.6
O2S12(V) 0.445
O2S21(V) 0.365
ST FTRM21(%) -1.6
O2S22(V) 0.445
OBD2 STAT CA
FRAME: 3 TM: 7.3
MIL STATUS Off
ABSLT TPS(%) 11.8
ENG SPEED(RPM) 1007
CALC LOAD(%) 3.1
MAF(LB/M) 1.28
MAP("HG) 20.1
COOLANT(°F) 169
IAT(°F) 61
IGN ADV(°) 21.0
SECOND AIR ATMOS
ST FTRM1(%) 0.0
ST FTRM2(%) -3.1
LT FTRM1(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.545
ST FTRM11(%) 1.6
O2S12(V) 0.445
O2S21(V) 0.790
ST FTRM21(%) -3.1
O2S22(V) 0.455
OBD2 STAT CA
FRAME: 4 TM: 9.9
MIL STATUS Off
ABSLT TPS(%) 11.8
ENG SPEED(RPM) 1009
CALC LOAD(%) 3.1
MAF(LB/M) 1.31
MAP("HG) 20.4
COOLANT(°F) 171
IAT(°F) 61
IGN ADV(°) 19.0
SECOND AIR ATMOS
ST FTRM1(%) 0.0
ST FTRM2(%) -4.7
LT FTRM1(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.655
ST FTRM11(%) 0.0
O2S12(V) 0.445
O2S21(V) 0.285
ST FTRM21(%) -3.1
O2S22(V) 0.445
OBD2 STAT CA
FRAME: 5 TM: 12.2
MIL STATUS Off
ABSLT TPS(%) 11.8
ENG SPEED(RPM) 1008
CALC LOAD(%) 3.5
MAF(LB/M) 1.30
MAP("HG) 20.1
COOLANT(°F) 171
IAT(°F) 59
IGN ADV(°) 17.5
SECOND AIR ATMOS
ST FTRM1(%) 0.0
ST FTRM2(%) -3.1
LT FTRM1(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.280
ST FTRM11(%) 0.8
O2S12(V) 0.445
O2S21(V) 0.265
ST FTRM21(%) 0.8
O2S22(V) 0.450
OBD2 STAT CA
FRAME: 6 TM: 14.6
MIL STATUS Off
ABSLT TPS(%) 14.5
ENG SPEED(RPM) 1794
CALC LOAD(%) 4.3
MAF(LB/M) 1.72
MAP("HG) 12.7
COOLANT(°F) 171
IAT(°F) 61
IGN ADV(°) 41.0
SECOND AIR ATMOS
ST FTRM1(%) 2.3
ST FTRM2(%) -7.8
LT FTRM1(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.495
ST FTRM11(%) 0.8
O2S12(V) 0.445
O2S21(V) 0.220
ST FTRM21(%) -2.3
O2S22(V) 0.445
OBD2 STAT CA
FRAME: 7 TM: 17.0
MIL STATUS Off
ABSLT TPS(%) 15.7
ENG SPEED(RPM) 1572
CALC LOAD(%) 5.1
MAF(LB/M) 1.88
MAP("HG) 15.1
COOLANT(°F) 171
IAT(°F) 59
IGN ADV(°) 41.0
SECOND AIR ATMOS
ST FTRM1(%) 17.2
ST FTRM2(%) 2.3
LT FTRM1(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 1.035
ST FTRM11(%) 0.0
O2S12(V) 0.445
O2S21(V) 0.235
ST FTRM21(%) 0.0
O2S22(V) 0.445
OBD2 STAT CA
FRAME: 8 TM: 19.4
MIL STATUS Off
ABSLT TPS(%) 15.3
ENG SPEED(RPM) 1493
CALC LOAD(%) 4.7
MAF(LB/M) 2.23
MAP("HG) 16.8
COOLANT(°F) 171
IAT(°F) 59
IGN ADV(°) 40.5
SECOND AIR ATMOS
ST FTRM1(%) 15.6
ST FTRM2(%) 7.0
LT FTRM1(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.210
ST FTRM11(%) 11.7
O2S12(V) 0.445
O2S21(V) 0.990
ST FTRM21(%) 5.5
O2S22(V) 0.450
OBD2 STAT CA
FRAME: 9 TM: 21.9
MIL STATUS Off
ABSLT TPS(%) 13.3
ENG SPEED(RPM) 1741
CALC LOAD(%) 4.3
MAF(LB/M) 1.63
MAP("HG) 12.7
COOLANT(°F) 169
IAT(°F) 59
IGN ADV(°) 38.0
SECOND AIR ATMOS
ST FTRM1(%) -1.6
ST FTRM2(%) -8.6
LT FTRM1(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.245
ST FTRM11(%) 0.8
O2S12(V) 0.440
O2S21(V) 0.170
ST FTRM21(%) 0.8
O2S22(V) 0.440
OBD2 STAT CA
FRAME: 10 TM: 24.4
MIL STATUS Off
ABSLT TPS(%) 11.4
ENG SPEED(RPM) 1052
CALC LOAD(%) 3.1
MAF(LB/M) 1.29
MAP("HG) 20.1
COOLANT(°F) 169
IAT(°F) 59
IGN ADV(°) 20.5
SECOND AIR ATMOS
ST FTRM1(%) 1.6
ST FTRM2(%) 0.0
LT FTRM1(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.610
ST FTRM11(%) 0.8
O2S12(V) 0.445
O2S21(V) 0.885
ST FTRM21(%) -0.8
O2S22(V) 0.445
OBD2 STAT CA
FRAME: 11 TM: 26.9
MIL STATUS Off
ABSLT TPS(%) 11.4
ENG SPEED(RPM) 1052
CALC LOAD(%) 3.1
MAF(LB/M) 1.28
MAP("HG) 20.1
COOLANT(°F) 169
IAT(°F) 59
IGN ADV(°) 21.0
SECOND AIR ATMOS
ST FTRM1(%) 0.0
ST FTRM2(%) -3.1
LT FTRM1(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.400
ST FTRM11(%) -0.8
O2S12(V) 0.450
O2S21(V) 0.265
ST FTRM21(%) -1.6
O2S22(V) 0.440
OBD2 STAT CA
FRAME: 12 TM: 29.4
MIL STATUS Off
ABSLT TPS(%) 11.4
ENG SPEED(RPM) 1035
CALC LOAD(%) 3.1
MAF(LB/M) 1.26
MAP("HG) 20.1
COOLANT(°F) 169
IAT(°F) 59
IGN ADV(°) 21.0
SECOND AIR ATMOS
ST FTRM1(%) 0.0
ST FTRM2(%) -1.6
LT FTRM1(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.175
ST FTRM11(%) 0.0
O2S12(V) 0.445
O2S21(V) 0.165
ST FTRM21(%) 0.0
O2S22(V) 0.445
OBD2 STAT CA
FRAME: 13 TM: 31.8
MIL STATUS Off
ABSLT TPS(%) 12.9
ENG SPEED(RPM) 0
CALC LOAD(%) 0.8
MAF(LB/M) 0.37
MAP("HG) 29.8
COOLANT(°F) 169
IAT(°F) 59
IGN ADV(°) 0.0
SECOND AIR ATMOS
ST FTRM1(%) 0.0
ST FTRM2(%) 0.0
LT FTRM1(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 OPEN
FUEL SYS 2 OPEN
O2S11(V) 0.145
ST FTRM11(%) 0.0
O2S12(V) 0.445
O2S21(V) 0.140
ST FTRM21(%) 0.0
O2S22(V) 0.450
OBD2 STAT CA
FRAME: 14 TM: 34.1
MIL STATUS Off
ABSLT TPS(%) 14.1
ENG SPEED(RPM) 0
CALC LOAD(%) 0.8
MAF(LB/M) 0.37
MAP("HG) 29.8
COOLANT(°F) 171
IAT(°F) 61
IGN ADV(°) 0.0
SECOND AIR ATMOS
ST FTRM1(%) 0.0
ST FTRM2(%) 0.0
LT FTRM1(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 OPEN
FUEL SYS 2 OPEN
O2S11(V) 0.135
ST FTRM11(%) 0.0
O2S12(V) 0.450
O2S21(V) 0.130
ST FTRM21(%) 0.0
O2S22(V) 0.445
OBD2 STAT CA
FRAME: 15 TM: 37.9
MIL STATUS Off
ABSLT TPS(%) 14.1
ENG SPEED(RPM) 0
CALC LOAD(%) 0.8
MAF(LB/M) 0.37
MAP("HG) 29.8
COOLANT(°F) 171
IAT(°F) 61
IGN ADV(°) 0.0
SECOND AIR ATMOS
ST FTRM1(%) 0.0
ST FTRM2(%) 0.0
LT FTRM1(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 OPEN
FUEL SYS 2 OPEN
O2S11(V) 0.130
ST FTRM11(%) 0.0
O2S12(V) 0.450
O2S21(V) 0.120
ST FTRM21(%) 0.0
O2S22(V) 0.450
OBD2 STAT CA
FRAME: 16 TM: 40.3
MIL STATUS Off
ABSLT TPS(%) 14.1
ENG SPEED(RPM) 0
CALC LOAD(%) 0.0
MAF(LB/M) 0.00
MAP("HG) 29.8
COOLANT(°F) 171
IAT(°F) 61
IGN ADV(°) 0.0
SECOND AIR ATMOS
ST FTRM1(%) 0.0
ST FTRM2(%) 0.0
LT FTRM1(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 OPEN
FUEL SYS 2 OPEN
O2S11(V) 0.125
ST FTRM11(%) 0.0
O2S12(V) 0.445
O2S21(V) 0.115
ST FTRM21(%) 0.0
O2S22(V) 0.445
OBD2 STAT CA
list of mods
list of mods
ported oil pump
timing chain
ms3 cam
prc227 heads
ported 90mm tb
fast102mm intake
stock mass air flow
1.72 rockers
ls7 lifters
fast fuel rails
42lb injectors
vararam cai
lt headers
rpm stage 3 rear
342 gear
vig 3800 stall
I/M Monitors
Since DTCs Cleared
Misfire Monitor ok
Fuel System Mon ok
Comp Component ok
Catalyst Mon ok
Htd Catalyst n/a
Evap System Mon inc
Sec Air System inc
A/C Refrig Mon n/a
Oxygen Sens Mon inc
Oxygen Sens Htr ok
EGR/VVT Sys Mon n/a
DTCs (Codes)
P0103 ENG $10
Input
HISTORY CURRENT
Record Data
FRAME: 0 TM: 0.0
MIL STATUS Off
ABSLT TPS(%) 11.8
ENG SPEED(RPM) 987
CALC LOAD(%) 3.5
MAF(LB/M) 1.29
MAP("HG) 20.4
COOLANT(°F) 169
IAT(°F) 61
IGN ADV(°) 16.0
SECOND AIR ATMOS
ST FTRM1(%) 0.0
ST FTRM2(%) -2.3
LT FTRM1(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.240
ST FTRM11(%) 0.8
O2S12(V) 0.445
O2S21(V) 0.300
ST FTRM21(%) -3.1
O2S22(V) 0.445
OBD2 STAT CA
FRAME: 1 TM: 2.3
MIL STATUS Off
ABSLT TPS(%) 11.8
ENG SPEED(RPM) 988
CALC LOAD(%) 3.5
MAF(LB/M) 1.32
MAP("HG) 20.1
COOLANT(°F) 169
IAT(°F) 61
IGN ADV(°) 21.5
SECOND AIR ATMOS
ST FTRM1(%) 0.0
ST FTRM2(%) -1.6
LT FTRM1(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.435
ST FTRM11(%) -0.8
O2S12(V) 0.445
O2S21(V) 0.855
ST FTRM21(%) -2.3
O2S22(V) 0.445
OBD2 STAT CA
FRAME: 2 TM: 4.8
MIL STATUS Off
ABSLT TPS(%) 11.8
ENG SPEED(RPM) 1009
CALC LOAD(%) 3.1
MAF(LB/M) 1.29
MAP("HG) 20.1
COOLANT(°F) 169
IAT(°F) 59
IGN ADV(°) 18.0
SECOND AIR ATMOS
ST FTRM1(%) 0.0
ST FTRM2(%) -3.9
LT FTRM1(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.870
ST FTRM11(%) 1.6
O2S12(V) 0.445
O2S21(V) 0.365
ST FTRM21(%) -1.6
O2S22(V) 0.445
OBD2 STAT CA
FRAME: 3 TM: 7.3
MIL STATUS Off
ABSLT TPS(%) 11.8
ENG SPEED(RPM) 1007
CALC LOAD(%) 3.1
MAF(LB/M) 1.28
MAP("HG) 20.1
COOLANT(°F) 169
IAT(°F) 61
IGN ADV(°) 21.0
SECOND AIR ATMOS
ST FTRM1(%) 0.0
ST FTRM2(%) -3.1
LT FTRM1(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.545
ST FTRM11(%) 1.6
O2S12(V) 0.445
O2S21(V) 0.790
ST FTRM21(%) -3.1
O2S22(V) 0.455
OBD2 STAT CA
FRAME: 4 TM: 9.9
MIL STATUS Off
ABSLT TPS(%) 11.8
ENG SPEED(RPM) 1009
CALC LOAD(%) 3.1
MAF(LB/M) 1.31
MAP("HG) 20.4
COOLANT(°F) 171
IAT(°F) 61
IGN ADV(°) 19.0
SECOND AIR ATMOS
ST FTRM1(%) 0.0
ST FTRM2(%) -4.7
LT FTRM1(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.655
ST FTRM11(%) 0.0
O2S12(V) 0.445
O2S21(V) 0.285
ST FTRM21(%) -3.1
O2S22(V) 0.445
OBD2 STAT CA
FRAME: 5 TM: 12.2
MIL STATUS Off
ABSLT TPS(%) 11.8
ENG SPEED(RPM) 1008
CALC LOAD(%) 3.5
MAF(LB/M) 1.30
MAP("HG) 20.1
COOLANT(°F) 171
IAT(°F) 59
IGN ADV(°) 17.5
SECOND AIR ATMOS
ST FTRM1(%) 0.0
ST FTRM2(%) -3.1
LT FTRM1(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.280
ST FTRM11(%) 0.8
O2S12(V) 0.445
O2S21(V) 0.265
ST FTRM21(%) 0.8
O2S22(V) 0.450
OBD2 STAT CA
FRAME: 6 TM: 14.6
MIL STATUS Off
ABSLT TPS(%) 14.5
ENG SPEED(RPM) 1794
CALC LOAD(%) 4.3
MAF(LB/M) 1.72
MAP("HG) 12.7
COOLANT(°F) 171
IAT(°F) 61
IGN ADV(°) 41.0
SECOND AIR ATMOS
ST FTRM1(%) 2.3
ST FTRM2(%) -7.8
LT FTRM1(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.495
ST FTRM11(%) 0.8
O2S12(V) 0.445
O2S21(V) 0.220
ST FTRM21(%) -2.3
O2S22(V) 0.445
OBD2 STAT CA
FRAME: 7 TM: 17.0
MIL STATUS Off
ABSLT TPS(%) 15.7
ENG SPEED(RPM) 1572
CALC LOAD(%) 5.1
MAF(LB/M) 1.88
MAP("HG) 15.1
COOLANT(°F) 171
IAT(°F) 59
IGN ADV(°) 41.0
SECOND AIR ATMOS
ST FTRM1(%) 17.2
ST FTRM2(%) 2.3
LT FTRM1(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 1.035
ST FTRM11(%) 0.0
O2S12(V) 0.445
O2S21(V) 0.235
ST FTRM21(%) 0.0
O2S22(V) 0.445
OBD2 STAT CA
FRAME: 8 TM: 19.4
MIL STATUS Off
ABSLT TPS(%) 15.3
ENG SPEED(RPM) 1493
CALC LOAD(%) 4.7
MAF(LB/M) 2.23
MAP("HG) 16.8
COOLANT(°F) 171
IAT(°F) 59
IGN ADV(°) 40.5
SECOND AIR ATMOS
ST FTRM1(%) 15.6
ST FTRM2(%) 7.0
LT FTRM1(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.210
ST FTRM11(%) 11.7
O2S12(V) 0.445
O2S21(V) 0.990
ST FTRM21(%) 5.5
O2S22(V) 0.450
OBD2 STAT CA
FRAME: 9 TM: 21.9
MIL STATUS Off
ABSLT TPS(%) 13.3
ENG SPEED(RPM) 1741
CALC LOAD(%) 4.3
MAF(LB/M) 1.63
MAP("HG) 12.7
COOLANT(°F) 169
IAT(°F) 59
IGN ADV(°) 38.0
SECOND AIR ATMOS
ST FTRM1(%) -1.6
ST FTRM2(%) -8.6
LT FTRM1(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.245
ST FTRM11(%) 0.8
O2S12(V) 0.440
O2S21(V) 0.170
ST FTRM21(%) 0.8
O2S22(V) 0.440
OBD2 STAT CA
FRAME: 10 TM: 24.4
MIL STATUS Off
ABSLT TPS(%) 11.4
ENG SPEED(RPM) 1052
CALC LOAD(%) 3.1
MAF(LB/M) 1.29
MAP("HG) 20.1
COOLANT(°F) 169
IAT(°F) 59
IGN ADV(°) 20.5
SECOND AIR ATMOS
ST FTRM1(%) 1.6
ST FTRM2(%) 0.0
LT FTRM1(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.610
ST FTRM11(%) 0.8
O2S12(V) 0.445
O2S21(V) 0.885
ST FTRM21(%) -0.8
O2S22(V) 0.445
OBD2 STAT CA
FRAME: 11 TM: 26.9
MIL STATUS Off
ABSLT TPS(%) 11.4
ENG SPEED(RPM) 1052
CALC LOAD(%) 3.1
MAF(LB/M) 1.28
MAP("HG) 20.1
COOLANT(°F) 169
IAT(°F) 59
IGN ADV(°) 21.0
SECOND AIR ATMOS
ST FTRM1(%) 0.0
ST FTRM2(%) -3.1
LT FTRM1(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.400
ST FTRM11(%) -0.8
O2S12(V) 0.450
O2S21(V) 0.265
ST FTRM21(%) -1.6
O2S22(V) 0.440
OBD2 STAT CA
FRAME: 12 TM: 29.4
MIL STATUS Off
ABSLT TPS(%) 11.4
ENG SPEED(RPM) 1035
CALC LOAD(%) 3.1
MAF(LB/M) 1.26
MAP("HG) 20.1
COOLANT(°F) 169
IAT(°F) 59
IGN ADV(°) 21.0
SECOND AIR ATMOS
ST FTRM1(%) 0.0
ST FTRM2(%) -1.6
LT FTRM1(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
O2S11(V) 0.175
ST FTRM11(%) 0.0
O2S12(V) 0.445
O2S21(V) 0.165
ST FTRM21(%) 0.0
O2S22(V) 0.445
OBD2 STAT CA
FRAME: 13 TM: 31.8
MIL STATUS Off
ABSLT TPS(%) 12.9
ENG SPEED(RPM) 0
CALC LOAD(%) 0.8
MAF(LB/M) 0.37
MAP("HG) 29.8
COOLANT(°F) 169
IAT(°F) 59
IGN ADV(°) 0.0
SECOND AIR ATMOS
ST FTRM1(%) 0.0
ST FTRM2(%) 0.0
LT FTRM1(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 OPEN
FUEL SYS 2 OPEN
O2S11(V) 0.145
ST FTRM11(%) 0.0
O2S12(V) 0.445
O2S21(V) 0.140
ST FTRM21(%) 0.0
O2S22(V) 0.450
OBD2 STAT CA
FRAME: 14 TM: 34.1
MIL STATUS Off
ABSLT TPS(%) 14.1
ENG SPEED(RPM) 0
CALC LOAD(%) 0.8
MAF(LB/M) 0.37
MAP("HG) 29.8
COOLANT(°F) 171
IAT(°F) 61
IGN ADV(°) 0.0
SECOND AIR ATMOS
ST FTRM1(%) 0.0
ST FTRM2(%) 0.0
LT FTRM1(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 OPEN
FUEL SYS 2 OPEN
O2S11(V) 0.135
ST FTRM11(%) 0.0
O2S12(V) 0.450
O2S21(V) 0.130
ST FTRM21(%) 0.0
O2S22(V) 0.445
OBD2 STAT CA
FRAME: 15 TM: 37.9
MIL STATUS Off
ABSLT TPS(%) 14.1
ENG SPEED(RPM) 0
CALC LOAD(%) 0.8
MAF(LB/M) 0.37
MAP("HG) 29.8
COOLANT(°F) 171
IAT(°F) 61
IGN ADV(°) 0.0
SECOND AIR ATMOS
ST FTRM1(%) 0.0
ST FTRM2(%) 0.0
LT FTRM1(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 OPEN
FUEL SYS 2 OPEN
O2S11(V) 0.130
ST FTRM11(%) 0.0
O2S12(V) 0.450
O2S21(V) 0.120
ST FTRM21(%) 0.0
O2S22(V) 0.450
OBD2 STAT CA
FRAME: 16 TM: 40.3
MIL STATUS Off
ABSLT TPS(%) 14.1
ENG SPEED(RPM) 0
CALC LOAD(%) 0.0
MAF(LB/M) 0.00
MAP("HG) 29.8
COOLANT(°F) 171
IAT(°F) 61
IGN ADV(°) 0.0
SECOND AIR ATMOS
ST FTRM1(%) 0.0
ST FTRM2(%) 0.0
LT FTRM1(%) 0.0
LT FTRM2(%) 0.0
VEH SPEED(MPH) 0
FUEL SYS 1 OPEN
FUEL SYS 2 OPEN
O2S11(V) 0.125
ST FTRM11(%) 0.0
O2S12(V) 0.445
O2S21(V) 0.115
ST FTRM21(%) 0.0
O2S22(V) 0.445
OBD2 STAT CA
You asked the same question in this post, right?
http://forums.corvetteforum.com/c5-t...need-help.html
Ron
Ron
The two of the better in the Detroit area are Dr Phil and Greg Bannish of Calibrated Success. If you still have problems after today contact one of the above.
