Bolt-On Tune Numbers
This was right after I snapped the head off of one of the TB bolts as well in the parking lot. Talk about bad luck. But the seal held absolutely fine with only 2 bolts. I'm hoping it's loose enough in the intake manifold that I can just turn it out by hand. If not, I guess I'll have fun removing the intake manifold to use pliers or drill it out.
Blue was the baseline with factory tune. Red was the 4th run after tune. Final 5th run yielded ~.5hp/.25tq less than 4th.
