Gear change / HP Tuners
St. Jude Donor '10
I ordered a new diff from RPM today and couldn't resist going to a 3.73 over the 3.42 that is in the car now. Using HP Tuners you can enter your gear ratio under the speedo settings but not sure if it needs to be changed anywhere else. Can anyone confirm if this is the only setting?
Car is a 2000 coupe.
Thanks!
Thanks!
