Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-21-2012, 04:21 PM   #1
dkulsy
Junior Member
dkulsy's Avatar
Default Vacuum leak
If there was a possibility of a vacuum leak, how would you look - spray some kind of cleaner or?
thanks
dkulsy is offline   Reply With Quote
Old 11-25-2012, 11:41 AM   #2
tblu92
CF Senior Member
St. Jude Donor '13
tblu92's Avatar
Yes ---at idle spray some Brake-clean around all the hoses and connections--on the T-Body where it meets the manifold---Brake clean wil make the engine want to DIE or STUMBLE if there is a vacuuum leak-- OR you can use starting fluid but the engine RPM's will flare up if there is a leak--
tblu92 is offline   Reply With Quote
Old 12-09-2012, 08:09 PM   #3
superjet701k
CF Senior Member
superjet701k's Avatar
superjet701k
Quote:
Carefull if you have a shorted out spark plug wire starting fluid will make a big fireball. It killed my neighbor 15 years ago. He inhaled the fireball.
superjet701k is offline   Reply With Quote
Old 12-10-2012, 11:45 AM   #4
tblu92
CF Senior Member
St. Jude Donor '13
tblu92's Avatar
Quote:
Wow--so sorry to hear
starting fluid would be extremly dangerous to use --be careful--WD 40 or something not so flamable would be best to create a stumble/dieing--Brakeclean is more flamable but not as much as starting fluid--
Old 12-12-2012, 11:19 AM   #5
Ronnie_W
CF Senior Member
Quote:
thanks
I just found my leak by attaching compressed air to one of the vac hoses. You need to be able to keep the pressure down so you don''t blow off any of the hoses. The leak was easy to find by listening to the air escapine. Of course you do this with the engine off.
Ronnie_W is offline   Reply With Quote
Old 12-12-2012, 08:26 PM   #6
StKnoWhere
Support Corvetteforum!
StKnoWhere's Avatar
Quote:
very smart idea!
StKnoWhere is offline   Reply With Quote
Reload this Page Vacuum leak
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
