C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
P0410 passenger side check valve
Old 11-09-2012, 03:54 PM
celarriviere
celarriviere's Avatar
Default P0410 passenger side check valve
Here is my solution for P0410. I had a bad passenger side valve and elected not to remove the intake to change it.
I got this idea from a Y_Tube-video, but made a few changes.
Good luck
I updated the info today. so proud of myself I wanted to get the info out as quick as I could. These directions should be more coherent!!!
File Type: pdf
Old 03-19-2013, 09:26 PM
RonJ
RonJ's Avatar
Any idea of the difference between the P0410 code and the P1416 code?
I believe the P1416 is the RS check valve on our C5's. What is a P0410 on our cars?
Ron J
Quick Reply: P0410 passenger side check valve
