reduced engine power post FAST install
1 Post
Hey guys, I have a 2001 C5 and I removed my intake to put the FAST 90mm on and I got a deal on a used ls2 tb with the casper harness. Well I finished at 2 am in rush to get ready for the drag strip, drove 2 hours there and noticed that soon as I hit full throttle the car would go into "REDUCED ENGINE POWER" mode and SERVICE TRACTION SYSTEM and SERVICE ACTIVE HANDLING would go on. Soon as I turned my car off and back on it would be fine. Until of course, i hit full throttle. We hooked it up to EFI live and came up with p1516 which is the throttle actuator control or whatever it was. So, I'm trying to figure out if its a ****** ls2 throttle body that I got or if its the casper wiring harness thats messed up. According to EFI live the car goes into reduced engine mode with anything over 84% throttle, even if the car is off. Which makes me think it probably isnt a tuning issue due to increased air flow.
PS before I get flamed, I did look up this code and common problems online for a while, seen a lot of similar problems, but no sollution yet.
Former Vendor
you have to change the tbs settings if your going from a 78mm to a 90mm . if not you get reduced engine power b/c it falls out of the maps range. retune the parameters and you should be ok.
1 Post
I understand, but my biggest question is... Why the hell would the car go into limp mode with the car off, that doesn't sound tune related.. He said he tried adjusting some of the tables. Do you know what that could be? Almost seems more like a bad t.b/harness issue
if it has a bronze blade it will not work. that is an ls3/ newer ls7 tb. I had the same problem when I originally bought an ls7 tb with a bronze blade. didnt matter what we did to the tune, wouldnt work. bought an ls2 tb with a silver blade and problem solved.
i had a simular problem ,its the tune.i put a 102 mm without the harness,because with the ls2 and ls3 tb i was having problems,the tables have to be switched ,im not a tunner and we are still working on mine.drove it home tonight ,and i get service steering colum .but car runs like a raped ape.
Platinum Supporting Vendor
The silver blade TB electronics had 3 circuits in it for app, the gold color blade has two. They are not interchangable, does not matter what table they are trying to calibrate it will not work.
