Re-Tune Needed ??
yes, you'll have to retune to adjust for the larger injectors. BTW, which 42lb injectors are you currently running?
I ask because I just installed some Delphi 42lb injectors and would love to see the injector tables if you have the same ones so I can compare my adjustments.
How did you max out the Ford Green Tops? Are you boosted? Either way, yes you would definately need a tune. Depending on how good your tune was already, you might get away with just changing the injector data. I see you live in Corpus Christi and I can change that data for you for $125. PM me if you're interested
