You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Recieved the Infamous "REDUCED ENGINE POWER" message :/
It threw a few codes
most recent-
P1514 Throttlebody performance
C1278 TCS Temporarily Inhibited by PCM
DTC P1515 Control Module Throttle Actuator Position Performance
DTC P1516 Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance
This has been doing this on/off for a while. It was actually fine for a few months. So I didnt bother messing with it.
It stalled on me a few times when driving at low speeds, also it feels like it surges/bogs a little on its own when idling/driving. that usually happens a few mins before it sets the codes and then the REP light comes on
Could this be a TAC module going bad? From what I've read, this reduced engine power crap seems to be a common problem.
Any ideas on what I should do?
I figured this weekend I'll-
Check ground wires- front ones had a lil corrosion. I cleaned those up.
Check connection at TAC module
check to see if throttle blade is sticking- Checked and it's not sticking
Any other ideas? All help is appreciated
It may be because the year, but there's a table in your ECM, that governs the density of year entering the motor. Its more like a threshold amount, and can happen with intake + exhaust boltons at the least. I've gotten it a few times before I found the table I needed to change. Ever since I did that, these codes have never come up again.
mods- 2001 vette, auto, Fast 90mm intake and tb, vararam, 25% UD pulley, longtubes, off road x pipe, staight pipes for an axleback, 3400 converter, 3.42 gears.
UPDATE- I cleaned up those ground connectors up front in the lil plastic cases. also switched out my TPS for one that I had from another TB. So far so good But then again, it was ok for a few weeks when i didnt do anything to it lol. Only time will tell
I have hp tuners, but my laptop is broken. looking to get a replacement very soon
Hi---don't panic easy fix---Its a common isssue on modded LS's
NOTHING is wrong with your throtttle body or communucation or your Tracttion Control or ABS
The P1514 is the root cause of all of the codes and "reduecd power mode "
When modding-- you eng's airflow will become greater than the "predicted airflow " in your tune --All you have to to is to go to the
"Predited Airflow table" (in EFILIVE table C6101") and ADD about
30-40% to the ENTIRE table--It does require use or either HP or EFILIVE to make these changes- Once changed it won't go into red. power mode--- In the mean time -all you have to do is start your car and turn it off 3 times and the red. power will be turned off and reset
Simply turning off the DTC permanently or deleting the codes won't do it either---
The reduced power mode uses the ABS and TC systems to redsuce the power--hence all the ABS and TC codes--They should disappear after the correction-----
I'm sure this is a dumb question; but, I Ned to ask anyway before I spend a lot of time and money troubleshooting my problem.
The car was wrecked (not by me). The air bags deployed and have not been reset. There is a wire to the drivers side front brakes missing ( I assume this is the ABS lead)...
Will this cause the Reduced Engine Power message? I cannot reset no matter what I try. Cleaned all the engine area grounds, etc.
I forgot to check back here lol. I have HP tuners. I'll definately look into that. big thanks!
98tadriver; I had the same issues as you listed. I did a lot of research and ended up replacing my ignition and the car has been great since. The brass pins that make contact with the metal tabs inside begin to arc and wear down due to the high current that runs through the ignitiion. Once I popped open the old part sure enough 3 of the pins were bad which would reduce a clear flow and throw out codes of all kind and cripple the performance of the car overall.
no kidding? Luckily all has been well with my car. just out of curiosity,what part of he ignition did you replace?
