C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Can Tech2 update PCM Vin
Old 08-07-2020, 08:22 PM
Trog
Trog's Avatar
Default Can Tech2 update PCM Vin
I have a car in (2000) that does NOT have the correct vin in the PCM.... Causes issues when I try to capture freeze frames.
I've never had to change a PCM out on C5 so this is a new one for me. I do have HPTuners but would have to charge the guy licenses as I don't use it that often.
Thanks!
Old 08-08-2020, 12:30 AM
aaronc7
aaronc7's Avatar
There's a few open source options that can do that easily, as long as you have a compatible cable/dongle.
PCM hammer
LS Droid
Not sure about the Tech2!
Old 08-08-2020, 12:52 PM
Trog
Trog's Avatar
THanks.... Looking into these options.
I know the tech2 can read/save & flash PCM. The few things I've read, indicate you use the GM service tools with your computer to update the file & then dump it back. Was hoping someone had experience with just updating/fixing the VIN without having the GM "software subscription". Since I already have the tech2 this would be quickest..
Looking forward to more input
To Can Tech2 update PCM Vin
Quick Reply: Can Tech2 update PCM Vin
