Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-27-2010, 05:17 PM   #1
baro0k@eXtermination
CF Senior Member
baro0k@eXtermination's Avatar
ZOSick baro0k baro0k
Default troubleshooting code B0026 (airbag code)
i just back from a test for the car and when i parked @ home i surpassed with a airbag light was on and the code was B0026 so any idea need a help
baro0k@eXtermination is online now   Reply With Quote
Old 06-28-2010, 09:38 AM   #2
CF Senior Member
waiting for info
Old 06-29-2010, 07:31 PM   #3
ajg1915
CF Senior Member
St. Jude Donor '08
Support Corvetteforum!
ajg1915's Avatar
Quote:
Originally Posted by baro0k@eXtermination View Post
waiting for info
DTC B0022, B0024, or B0026
Circuit Description
The inflatable restraint steering wheel module deployment loop consists of the inflatable restraint steering wheel module, the inflatable restraint steering wheel module coil, and the steering wheel module high and low circuits. A shorting bar used within the steering wheel module coil connector shorts together the steering wheel module high and low circuits when the connector is disconnected. This helps to prevent unwanted deployment of the inflator module during servicing. During a frontal crash of sufficient force, the inflatable restraint sensing and diagnostic module (SDM) allows current to flow through the deployment loop in order to deploy the steering wheel module. When the ignition is turned ON, the SDM performs continuous diagnostic tests on the deployment loops to check for proper circuit continuity and for shorts to ground or voltage. If a malfunction is detected, a diagnostic trouble code (DTC) will be stored in memory.
Conditions for Running the DTC
Ignition 1 voltage is within the normal operating voltage range.
Conditions for Setting the DTC
DTC B0022 will set when the steering wheel module deployment loop resistance is less than 1.3 ohms for 300 milliseconds.
DTC B0024 will set when one of the following conditions occur:
Steering wheel module high circuits is more than 6 volts for 300 milliseconds.
Steering wheel module high circuit is less than 2 volts and steering wheel module deployment loop resistance is less than 6 ohms for 300 milliseconds.
DTC B0026 will set when one of the following conditions occurs:
Steering wheel module high circuit is less than 2 volts and the steering wheel module deployment loop resistance is more than 4.8 ohms for 500 milliseconds.
Steering wheel module deployment loop resistance is more than 6 ohms for 300 milliseconds.
Action Taken When the DTC Sets
The SDM commands the AIR BAG indicator ON via Class 2 serial data.
Conditions for Clearing the DTC
The condition responsible for setting the DTC no longer exists and the scan tool Clear DTCs function is used.
A history DTC will clear once 255 malfunction free ignition cycles have occurred.
Diagnostic Aids
The following are possible causes of the malfunction:
A short between the steering wheel module high and low circuits.
An open or a high resistance in the steering wheel module high or low circuits.
A short to ground or a short to voltage in the steering wheel module high or low circuits.
The steering wheel module coil connector
The SDM connector
A malfunctioning steering wheel module
A malfunctioning steering wheel module coil
A malfunctioning SDM
Thoroughly inspect the wiring and the connectors. An incomplete inspection of the wiring and the connectors may result in a misdiagnosis, causing a part replacement with the reappearance of the malfunction. If an intermittent malfunction exists, refer to Testing for Intermittent and Poor Connections in Wiring Systems.
Test Description
The numbers below refer to the step numbers on the diagnostic table.
This step tests to see if the malfunction is caused by the steering wheel module or by the steering wheel module coil.
This step tests to see what DTCs are present. If DTC B0022 is present, test for a short between the steering wheel module high and low circuits. If DTC B0024 is present, test the steering wheel module high and low circuits for an open and for high resistance. If DTC B0026 is present, test the steering wheel module high and low circuits for an open and for high resistance.
Step
Action
Yes
No
Schematic Reference: SIR Schematics
1
Did you perform the Diagnostic System Check-SIR?
Go to Step 2
Go to Diagnostic System Check - SIR
2
Turn OFF the ignition.
Disconnect the steering wheel module coil connector. Refer to Inflatable Restraint Steering Wheel Module Coil Replacement .
Inspect the component and harness sides of the steering wheel module coil connector for damage or corrosion that may cause the malfunction. Refer to Testing for Intermittent and Poor Connections and Connector Repairs in Wiring Systems.
Does the connector exhibit any signs of damage or corrosion?
Go to Step 3
Go to Step 4
3
If the component side of the steering wheel module coil connector is damaged, the steering wheel module coil must be replaced. Refer to Inflatable Restraint Steering Wheel Module Coil Replacement .
If the wiring harness side of steering wheel module coil connector is damaged, replace the harness side of the connector. Refer to Connector Repairs in Wiring Systems.
Did you complete the repair?
Go to Step 11
4
Install the J 38715-A SIR Driver/Passenger Load Tool to the harness side of the steering wheel module coil connector. Use BASE OF COLUMN connector.
Turn ON the ignition, with the engine OFF.
Use the scan tool to request SIR DTCs displayed.
Does the scan tool indicate that DTC B0022, B0024, or B0026 are current?
Go to Step 6
Go to Step 5
5
Disconnect and remove the J 38715-A .
Connect the steering wheel module coil connector.
Remove the steering wheel module. Refer to Inflatable Restraint Steering Wheel Module Replacement .
Use the J 38715-30A adapter to connect the J 38715-A to the upper steering wheel module coil connector on top of the steering column. Use STEERING COLUMN connector.
Go to Step 9
Go to Step 8
6
Disconnect and remove the J 38715-A and adapter.
Disconnect the inflatable restraint sensing and diagnostic module (SDM) connector. Refer to Inflatable Restraint Sensing and Diagnostic Module Replacement .
Inspect the SDM connector for damage or corrosion that may cause a malfunction in the steering wheel module high and/or low circuits. Refer to Testing for Intermittent and Poor Connections and Connector Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 11
Go to Step 7
7
If DTC B0024 is present, test the steering wheel module high and low circuits for a short to ground or a short to voltage.
If DTC B0026 is present, test the steering wheel module high and low circuits for an open or high resistance.
All the above conditions refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 11
Go to Step 10
8
Replace the steering wheel module. Refer to Inflatable Restraint Steering Wheel Module Replacement .
Did you complete the replacement?
Go to Step 11
9
Replace the steering wheel module coil. Refer to Inflatable Restraint Steering Wheel Module Coil Replacement .
Go to Step 11
10
Replace the SDM. Refer to Inflatable Restraint Sensing and Diagnostic Module Replacement .
Go to Step 11
11
Connect all SIR components.
Use the scan tool in order to clear the DTCs.
Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text.
Does the DTC reset?
ajg1915 is offline   Reply With Quote
Reload this Page troubleshooting code B0026 (airbag code)
Tags
airbag, b0022, b0024, b0026, c5, code, connector, corvette, disconnected, dtc, picture, resistance, sir, srs, troubleshoot
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
