Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-20-2009, 05:40 PM   #1
TxBandit
CF Member
Default Drill a hole in the TB Plate?
Recently I had the car on the dyno and have been driving it around a couple of days each week. I've noticed that if I'm cruising at a steady speed and bump the car into nuetral(6 speed) the car will try to hunt for idle. Typically this will happen when I approach redlights and/or stop signs. So, I called the tuner, explained the situation and he stated that I should drill a 7/32" diameter hole in the TB plate.
I've heard of doing this before, but is this REALLY the correct way to solve the problem?
Troy
TxBandit is offline   Reply With Quote
Old 11-20-2009, 06:06 PM   #2
Z06supercharged
CF Senior Member
A simple answer is NO!
You need to find another tuner.
You have a stock cam as well?
Z06supercharged is offline   Reply With Quote
Old 11-20-2009, 06:32 PM   #3
TxBandit
CF Member
Hmmm..looks like I need to update my profile!!
The car has a LS2 shortblock with L92 heads, LS3 intake/TB (no portwork on heads/intake/tb) and a custom cam, 236/244ish, ASP underdrive, Longtubes, catless X and corsa catback.
Troy
Old 11-20-2009, 08:50 PM   #4
Slow Z06
CF Senior Member
Slow Z06's Avatar
!!no!!
Slow Z06 is offline   Reply With Quote
Old 11-20-2009, 09:14 PM   #5
TurboBerserker
CF Senior Member
TurboBerserker's Avatar
Doesn't matter what your mods are, the answer is still no. You need a better tune.
TurboBerserker is offline   Reply With Quote
Old 11-20-2009, 10:31 PM   #6
Slow Z06
CF Senior Member
Slow Z06's Avatar
you need a new tuner. This was done back in the LS1 edit days, when there was no better option out there. With HPTuners and EFI live there is no need. Use someone else
Old 11-20-2009, 10:36 PM   #7
TxBandit
CF Member
Thanks all!!
It's interesting that LS1 Edit was mentioned....that's what was used to tune the car.
Anyone care to make a recommendation for a tuner in Houston?
Thanks,
Troy
Old 11-20-2009, 10:52 PM   #8
Slow Z06
CF Senior Member
Slow Z06's Avatar
england green
Old 11-20-2009, 11:50 PM   #9
Z06wanted
CF Senior Member
Z06wanted's Avatar
Quote:
Originally Posted by TXZ0603 View Post
england green
I have heard really good things about them.
Z06wanted is offline   Reply With Quote
Old 11-21-2009, 09:33 AM   #10
phils C5 vette
CF Senior Member
phils C5 vette's Avatar
Like the others have said. Find a new tuner.
__________________
www.TampaTuning.com
813-727-8720
Tuned by Tampa Tuning
[SIZE="5"]451.1 RWHP@ 5900 432.8 RWTQ@ 4900
phils C5 vette is offline   Reply With Quote
Old 11-22-2009, 06:56 PM   #11
Cajundude@EnglandGreen
Supporting Tuner
Houston Events Coordinator
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11
Support Corvetteforum!
Cajundude@EnglandGreen's Avatar
Location: ========= Houston, Texas www.englandgreen.com ============== Necessary Evil™ __ 281.464.2800
I'm sure we could probably dig up an extra blade for you somewhere around here.
Drilling a hole in a throttle body is a lazy man's way of tuning the idle. There is no reason to drill a hole.
Jason
__________________
3135 Fall Street
Houston, Texas 77054 USA
281 464 2800
sales@englandgreen.com
AIM/iChat: sales@englandgreen.com
Facebook: EnglandGreen.Corp
EnglandGreen Corp. is a high performance facility that specializes in C6 & C5 Corvettes.
© 1994-2011 EnglandGreen Corp. Necessary Evil™
Cajundude@EnglandGreen is offline   Reply With Quote
Old 11-22-2009, 10:18 PM   #12
98vettedave
CF Senior Member
98vettedave's Avatar
Send a message via Yahoo to 98vettedave
Jason
And that's the truth!!
98vettedave is offline   Reply With Quote
Old 11-23-2009, 12:23 PM   #13
Mike04
CF Senior Member
Mike04's Avatar
Mike04 is offline   Reply With Quote
Old 11-26-2009, 03:38 PM   #14
EG@EnglandGreen
Supporting Tuner
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
EG@EnglandGreen's Avatar
Location: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ ____________ 281.464.2800
englandgreen.corp englandgreen
Send a message via ICQ to EG@EnglandGreen Send a message via AIM to EG@EnglandGreen
Bring your baby down and we'll get you squared away.
Stephen
__________________
3135 Fall Street
281 464 2800
© 1994-2012 EnglandGreen Corp. Necessary Evil™
EG@EnglandGreen is offline   Reply With Quote
Old 11-27-2009, 09:15 PM   #15
Slowhawk
Premium Supporting Vendor
I have seen cars that needed a hole drilled to keep the idle blade opening in check but the setups are alot more extreme than yours.With your setup it looks like it just needs the base airflow adjusted. Pretty simple.
__________________
2011 Camaro SS ,synergy green -shop car
ARH headers,intake,Cam ect so far. 11.66 at 116mph weighing 4065lbs.
Old car-2002 Electron blue C5
Z06 catback,Edit tuned.
A+A P1 kit,Kook longtubes
507hp/477tq
2005 Avalanche,SOM,Corsa,tuned ,Single turbo kit 450hp/475tq at 7lbs of boost.
1999 Trans Am -420ci C5R motor -daily driver -10.2 at 130mph NA
Owner of www.Slowhawkperformance.com
LS1 tuning/building.
Slowhawk is offline   Reply With Quote
Old 11-28-2009, 08:32 AM   #16
mowton
CF Senior Member
mowton's Avatar
Quote:
From my understanding, the technical reason for the hole in the TB goes back to the "drive by cable" applications (i.e F-Bodys) as you needed to let more air in for modded (cammed) engines and still maintain the Idle Air Control (IAC) valve steps at idle to be in the 40-60 range (and mv's) to allow idle sufficient open (more air)/close (less air) adjustments.
Electronic Throttle Control egines don't usually need this as the PCM can adjust the throttle blade (tuner has control of these parameters) and the IAC is no longer used.
JMHO
Ed M
mowton is offline   Reply With Quote
Old 11-28-2009, 02:12 PM   #17
Slowhawk
JMHO
Ed M
That is true. But I've had Vette's idle at 30% throttle before.This is when the hole helps.
Also,alot of people over port the TB which does the same as a hole,just no hole.
As said though,the small setup above just needs tuning to correct.
__________________
507hp/477tq
Reload this Page Drill a hole in the TB Plate?
Tags
air, blade, body, c5, corvette, drill, drilling, hole, idle, ls2, plate, tb, throttle, valve, z06
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C5 idle problem stinker C5 Tech 9 07-13-2005 03:57 PM
Idle gone again--FAST 90 NEPTUNEBILL C5 Tech 17 06-29-2004 01:12 AM
Which cam in a full bolt-on 6-speed? i_york C5 Tech 13 03-16-2004 10:21 AM
RAM AIR FOR A C4 CORVETTE LT1CORVETTE C4 Tech/Performance 18 05-21-2003 06:17 AM
Why is it necessary to drill a small hole in the TB with an aftermarket cam? Tiger Shark C5 Tech 18 12-12-2001 12:20 AM
Heads and Cam Down Side? shftn6 C5 Tech 24 09-29-2001 04:37 PM
MTI's RAT III has 500 hp CONFIRMED :) Ram Air Tony C5 Tech 48 08-09-2001 04:17 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
