Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-11-2009, 06:21 PM   #1
jac1979
Junior Member
Default Low voltage reference problem
Ok well I started a thread in the tech/performance area but it's starting seem like my problem is more related to something in the PCM so I will try here and see if someone can help.
Problem started when the car completly staled, then would crank and I could only get the engine to sputter and it would not start. Took the car to the dealer, they said there is no fuel pressure so it needs a fuel pump. Since they were so very proud of thier fuel pump and labor, I ended up doing it myself. New fuel pump and car started but wouldn't run right. The engine knocks like it was out of time. Found some crispy wires going to the crankshaft position sensor...fixed those up and verifed the connection was good from sensor connector to pcm. Still same problem. Had someone come out with a scanner capable of reading the signal from the crankshaft position sensor, he said there was no signal. One of the wires going to the crankshaft position sensor is the low voltage reference. There is no low voltage reference. When the key is in run. The 12 volts is there as it should be. The diagram in my service manual shows the low voltage coming from the PCM so it seems like it is an internal problem with the PCM.
So my questions are...
Is there something that needs to be satisfied so that the low voltage will be present or should it always be there?
Is there a way to test the PCM to see if it is still good?
jac1979 is offline   Reply With Quote
Reload this Page Low voltage reference problem
Tags
2005, c5, c6, correct, corvette, low, nmsc, problem, problems, reference, test, voltage
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Please Post Secret Codes Again ! ALLEGRO C5 General 51 01-17-2005 12:21 AM
Starting problem solved??? RED-85-Z51 C4 Tech/Performance 14 04-10-2004 04:18 PM
I need urgent help. Andrade108 C5 Tech 18 03-25-2004 05:23 PM
CRAP, I need some help with this one! 212mike C5 Tech 16 08-27-2003 07:35 PM
Car Running Hot (Yes I've Done All the Usual Stuff) Langadorf C4 Tech/Performance 22 07-10-2002 11:14 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
