Thank you again for your all your business in October. It was another great month for us at PartsTaxi, and we owe it to our customers. We had a great cruise in last weekend with the local corvette clubs. It was nice to see more the 2 dozen cars turn out when the thermostat on the sign read 27 degrees at 8am. Unseasonably cold for here, this is the beach area LOL.
In running through some of our kit pricing, I found that GM lowered our pricing on quite a few items, so I am able to pass these savings on to you. I have also added quite a few more lines of what was popular and requested last month. As always, I will match any competitors total shipped price on any GM parts, not just what is listed here.
Please feel free to contact me with any questions or for assistance. You can call, email, pm ~ whatever works for you
2010 C6 Shifter Kit
25823572 - Shifter -
$120.41
15851631 - Knob -
$61.86
11609670 - Bolt -
$2.77
GM Magnetic Oil Drain Plug - 24241872 -
$14.65
C5 Maintenance Parts
12621258 - Iridium Spark Plug -
$5.88 each
10287788 - 1997 & 1998 Fuel Filter -
$12.18
19239926 - 1999-2004 Fuel Filter & Regulator -
$76.87
25042562 - 1997-2004 Air Filter -
$10.88
12572188 - Serpentine Belt -
$48.74
19172680 - A/C Compressor Belt -
$45.08
25329389 - UPF44 Oil Filter -
$8.22 each
19210283 - PF46 Oil Filter -
$4.78 each
GM Keyless Entry Transmitters/FOBS
10253839 - For 1997-1999 -
$75.87
10432147 - For 2000 Only -
$57.80
25695954 - For 2001 - 2004 #1 -
$58.88
25695955 - For 2001 - 2004 #2 -
$58.88
GM C5 Ceramic Brake Pads
88909667 - Front Ceramic Pad Kit -
$88.37
88909668 - Rear Ceramic Pad Kit -
$59.31
ACDelco Performance Drilled/Slotted Rotors
19183532 - Right Front Rotor -
$94.19
19183533 - Left Front Rotor -
$94.19
19183534 - Right Rear Rotor -
$87.09
19183535 - Left Rear Rotor -
$87.09
20822934 - Upgraded C6 Metal End Links -
$22.78
C6 Z06 Front and Rear Sway Bar Kit - Kit includes Front and Rear Stabilizer Bars for C6 Z06 and insulators -
$224.83
C6 Z51 Front and Rear Sway Bar Kit - Our most popular bar kit. Kit includes front and rear stabilizer bars for Z51 -
$191.84
C6 Z06 Brake Upgrade Kit - Kit includes both front calipers, both rear calipers, both front rotors, both rear rotors, front and rear GM OEM pads. We prefer not to substitute ACDelco as a replacement on this kit. -
$1799.99
C6 Z06 Shocks
10313647 - Front Shock -
$61.43 each
25819268 - Rear Shock -
$60.42 each
LS7 Clutch Kit - Kit includes LS7 Clutch and Flywheel - $431.97
C5 Tire Pressure Sensors
25773946 - 2001 - 2004 Sensor -
$38.98 each
25981210 - 1997 - 2000 Sensor -
$91.88 each
15234846 - 1997 - 2004 Nut -
$3.73 each
C5 Z06 Brake Pads
19181427 - Front Pad Kit -
$126.76
12530688 - Rear Pad Kit -
$57.65
12572683 - C5 Z06 Rear Differential Assembly -
$1249.96
C5 Z06 Springs
15233396 - Front -
$247.86
22188038 - Rear -
$531.48
Genuine GM C5 Bra (Front End Cover)
19202113 - Non Z06 C5 -
$82.74
GM LS2 Common Replacement Items
89017648 - LS2 Intake Manifold -
$289.57
12570790 - LS2 Thottle Body -
$297.82
12633511 - LS2 Fuel Rail -
$140.65
12568950 - LS2 Bare Block -
$1080.71
12615363 - LS2 Cylinder Head -
$477.98
Thanks!!!
Kevin
www.PartsTaxi.com
302-645-6221 x126
302-295-1240 - Fax
302-883-0227 - Parts Department Direct
