Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-07-2009, 07:56 PM   #1
T_Vert
CF Senior Member
Default o2s not oscilating, always at .450"ish"
I went w/ a rear sensor up front and it seemed to work for a while now I've noticed in HPT that they aren't oscillating. Even if I force it into closed loop in HPT.
Any advice?
Dave
T_Vert is offline   Reply With Quote
Old 11-08-2009, 08:42 AM   #2
edcmat-l1
Supporting Vendor
edcmat-l1's Avatar
Quote:
Any advice?
Dave
Disconnected, bad connection. When they go bad they rarely stick dead in the middle.
edcmat-l1 is offline   Reply With Quote
Old 11-08-2009, 03:16 PM   #3
T_Vert
CF Senior Member
replaced the o2 fuse and they started to oscillate again. Fuse only lasts for a few minutes though, I don't get it. Wires look fine, this is a 2nd set of sensors. The wiring hasnt been changed, this just started to happen all the sudden..
Old 11-09-2009, 06:42 PM   #4
T_Vert
CF Senior Member
I'm going to check the schematics tonight and see how the wire runs but if a fuse blows slowly, not instantly, does that indicate maybe a bad o2 sensor blowing fuse even if it works? Maybe too much internal resistance?
Reload this Page o2s not oscilating, always at .450"ish"
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
