Quote:
Originally Posted by Corvette Don
Will the LC-1 work with standard HpTuners?
No wideband will work the standard HP Tuners without modifying the GM engine harness. The HP Tuners PRO unit has the input and output provision for the tools like a wideband.
For full disclosure, I believe some guys are using a GM 5V input with their standard HP Tuners and a wideband sensor. It seems a little unnecessary when the PRO is much easier. A search on HPTuners forum will probably fill in the gaps if you're interested.
