Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-01-2009, 02:35 PM   #1
Toby Van Horn
CF Senior Member
Toby Van Horn's Avatar
Default efi live questions
I am looking to buy the EFI live V1.2, and had a question about data logging. It seems that it comes with 2 licences.
Can you log data for more than what is registered? or is it only for the two VINS?
What is the best wideband kit to use with EFI live?
Do you run a wideband on both the left and right banks?
The EFI live scanner holds 20 min, and more than that needs a notebook? How many parameters can you look at for that 20 min?
Toby Van Horn is offline   Reply With Quote
Old 11-02-2009, 12:01 AM   #2
BLKTA
CF Senior Member
The licensing is specific to the flash/tune part of the software. You can datalog any vehicle supported by EFiLive without using any licenses. Check their website for supported vehicles.
Quote:
What is the best wideband kit to use with EFI live? Do you run a wideband on both the left and right banks?
There are a variety of WB's out there and it comes down to personal choice and budget. I use the Innovate LM1 with serial cable. It's easy to install and works great. Single bank is more than adequate.
If you're referring to the V2 black box standalone datalogging, I recommend buying a 1g or 2g SD card that can store quite a bit of logs.
You can run quite a few parameters (or PID's as they're called) when datalogging with a laptop. There is limit when using the V2 blackbox for datalogging. They recommend 24 channels max for best sampling speed. Some PID's take more than one channel. I personally run more than that.
Checkout: http://forum.efilive.com for details.
BLKTA is offline   Reply With Quote
Old 11-02-2009, 12:22 AM   #3
Toby Van Horn
CF Senior Member
thanks, I am considering v1.2 as I have seen some good deals for used ones with vin license. I do want to make sure I get a wideband also. Thanks for the info
Reload this Page efi live questions
Tags
04, band, c6, corvette, data, efi, efilive, forum, licensing, live, logging, tuning, v1, v12, vette, vin, wide
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
If anyone can read EFI files, let me know what you think.. XCELER8 C5 Forced Induction/Nitrous 13 07-30-2005 04:48 PM
Took the car out tonight, EFI Live same time, few questions XCELER8 C5 Forced Induction/Nitrous 70 07-24-2005 12:43 PM
Predator Questions rbartick C5 Scan & Tune 14 10-10-2002 12:34 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
