Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-25-2009, 10:09 PM   #1
phils C5 vette
CF Senior Member
phils C5 vette's Avatar
Default Wideband AFR at idle and WOT
What's a good idle AFR and what's a good WOT AFR
I want to double check my numbers of 14.5 at idle and 12.7 at WOT?
ive been using a tailpipe sniffer so how much differance will i see if i used the header bung?
__________________
www.TampaTuning.com
813-727-8720
Tuned by Tampa Tuning
[SIZE="5"]451.1 RWHP@ 5900 432.8 RWTQ@ 4900
phils C5 vette is offline   Reply With Quote
Old 10-26-2009, 02:51 PM   #2
tblu92
CF Senior Member
tblu92's Avatar
Hi--there is usually about .2/.3 tenths AFR difference leaner if you measure it thru the cats and at the tailpipe--getting an accurate AFR (even with a wideband) at idle is tough as the AFR bounces all over the place--especially with a cam---
tblu92 is offline   Reply With Quote
Old 10-28-2009, 09:06 PM   #3
phils C5 vette
CF Senior Member
Old 10-29-2009, 12:33 AM   #4
mvvette97
CF Senior Member
St. Jude Donor '06-'07-'08-'09
mvvette97's Avatar
Send a message via Yahoo to mvvette97
with a bung in the header I like to see about 12.9 at WOT and at idle it will jump around from 14.6-15.3. Like said above with a cam the idle AFR will jump alot.
mvvette97 is offline   Reply With Quote
Reload this Page Wideband AFR at idle and WOT
Tags
afr, band, c5, corvette, good, idel, idle, ls1, open, throttle, tune, whats, wide, widw, wot
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
1/4 mile times ( Gtech pro ) adi4 C4 Tech/Performance 30 07-18-2005 08:07 PM
My baseline A/F ratio results using a Zeitronix Zt-2 MIKER C3 Tech/Performance 24 06-12-2005 04:58 PM
So is it LT5 history or an LT5 Landmark???? MrCrowley C4 ZR-1 Discussion 203 04-06-2005 07:05 PM
LG Motorsports C6 is here!!!! SPD DVA C6 Corvette General Discussion 176 09-27-2004 09:45 AM
Car bucks between 1500-2000 while cruising after 42# install HurricaneZ C5 Scan & Tune 12 07-13-2004 12:25 PM
O2 sensor mv at WOT for LT-1's? steve40th C4 Scan & Tune 9 07-06-2003 04:26 PM
Chasing the perfect LTFT "White Elephant" chuckster C5 Scan & Tune 14 12-24-2002 03:50 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
