Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-24-2009, 03:53 AM   #1
nitrouscharlie
CF Senior Member
nitrouscharlie's Avatar
Default P0134, and P0101, what the hell.
What would cause this code, and for some reason I cant get inspected. They say that my 02 sensor and 02 sensor heater "Not Ready"..? And my HVAC is "Not Ready" What does that mean, and could a tuner fix that.
Thanks guys,
Charlie
nitrouscharlie is offline   Reply With Quote
Old 10-26-2009, 10:07 PM   #2
tblu92
CF Senior Member
tblu92's Avatar
P0136 is a code for the REAR Driver's side 02 sensor--The ECM will run thru a squence of tests on various sensors to see if they are working--
these are called "readiness tests" after the tests are run the sensor monitors should turn to the "ready mode " IF you disconnect the battery--lose 12 volt power--download a tune--or even sometimes just run a scan --ALL the readiness monitors wil be re-set to "not ready" In order to have the monitors to turn to ready---you need to drive the car for 3 drive cycles--A drive cycle includes 3 dead cold starts-- and driving the car up to operating temps and driving it in several different ways--ie: on the freeway-around town and some WOT blasts---
If you continue to have this code or all the monitors won't go to ready after the drive cycles you may have a bad sensor -or a blown sensor heater fuse--Another fix is just to have all the rear 02 monitoring and sensing "tuned out" and have all the enablers turned OFF---If you have headers it's a good idea to do this anyway---Also on a performance tune many people turn the "COT" system off as well----this is the cat overtemp system--It adds fuel occasionally to your WOT AFR to cool the cats down--but this will take power away when you need it the most---I have had mine off for 5 years and still pass smog here in calif--It doesn't seem to hurt the cats at all--the fuel enrichment was around 11.0-1 far from my programmed 12.7 at WOT---really could feel it lay down-----
tblu92 is offline   Reply With Quote
Reload this Page P0136, what the hell.
Tags
c5, corvette, cot, p0136, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
