At our rental I was running a bunch of different differrent tunes, when I put in the 100% tune I noticed that my gauges stopped working on my dash. Anyone ever hear of tuning software causing this? Any ideas?
BTW, I ran 10.06 @ 139.79 at 80% throttle, restrictor plate, with a crappy 1.6 short time...I wanted to get the stock bottom end record back
Normally happens when you start flash while the gauges are still sweeping or right afterward. (not giving enough time after turning the key to on). If in HPtuners theres a "write entire" or "write all" option, doing that fixes ya right up. Duno if there's the same option in EFi.
[[posted mostly inebriated, so, spelling isn't my strong suit]]
Yes had this happen to me with EFI Live, use the Option that reloads the entire OS
Happened to me with EFILive.I just disconnect the battery and reconnect it and that worked...........Paul
I'm guessing this would have worked because my battery died for some reason and when I jumped the car, everything worked fine. I wonder if the dead bettery was a coincidence? Its fine now that I jumped it.
I'm guessing this would have worked because my battery died for some reason and when I jumped the car, everything worked fine. I wonder if the dead battery was a coincidence? Its fine now that I jumped it.
If you flash the pcm alot it will run down the battery.If you are just sitting there flashing your pcm and starting and shutting the car off then flashing.Ya know what I mean...............Paul
