Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-22-2009, 03:46 PM   #1
Quick 68
CF Senior Member
Quick 68's Avatar
Default MAF blew up on dyno and sensor compatibility ?
My LS6 MAF sensor broke in half on the dyno. I'm running the A&A kit with a Vortec T trim at 9psi. It burst when the throttle was released on the last dyno pull. My tuner said the relief valve was openining. What could have caused this problem? I need a new MAF and I was told a 6.0 truck MAF will also work. I'm trying to find one in a salvage yard is why I'm looking for other options other than an LS6. Can someone point me in the direction of what other MAFS will work?
Quick 68 is offline   Reply With Quote
Old 10-22-2009, 04:30 PM   #2
SiL3NtXWS6
CF Senior Member
SiL3NtXWS6's Avatar
Maybe it's time to step up to a Tial 50mm BOV? It's what I run.
SiL3NtXWS6 is offline   Reply With Quote
Old 10-22-2009, 05:25 PM   #3
AlwaysInBoost
CF Senior Member
AlwaysInBoost's Avatar
I have a tail 50mm and I still blew my MAF apart. I believe it was from over tightening the t-bolt clamps and the constant heating/cooling of the plastic. I was on track when it happened and didn't even realize until I got back to the pits.
IMO, a plastic MAF doesn't belong on an FI setup unless its pre-turbo. A&A makes a MAF skirt that will stop this from happening again, if you aren't going to go SD that would be the best option.
AlwaysInBoost is offline   Reply With Quote
Old 10-22-2009, 10:49 PM   #4
Slow Z06
CF Senior Member
Slow Z06's Avatar
Mafs blow up. I believe Andy has a girdle for it.
OH, 50mm Tial here. Blew up maf
Slow Z06 is offline   Reply With Quote
Old 10-23-2009, 02:41 AM   #5
Quick 68
CF Senior Member
Quick 68's Avatar
I ordered the girdle from A&A today. I need to get my car home from the tuner so I need to get a used MAFS for the time being. Is the 6.0 truck sensor the same as the LS6 as I was told? I'm sure it is much more common to find in a salvage yard than the LS6.
Old 10-23-2009, 02:04 PM   #6
Quick 68
CF Senior Member
Quick 68's Avatar
Any help as to what other MAF sensors are the same? I need to go find a MAF and pick up the car asap. Thanks
Reload this Page MAF blew up on dyno and sensor compatibility ?
Tags
blew, blowing, c5, dyno, ls6, maf, tune
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
