Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-21-2009, 07:27 PM   #1
FLAFLIER
CF Senior Member
Default Maggie tune question
I have a 99FRC that had a LPE top end kit installed at 15k miles in 2002. The car had 383hp and 360tq on Lingenfelters dyno at that time.
Just installed a 112 IC Maggie and had the car re tuned a couple of weeks ago. Although I was not concerned about having a 500+ RWHP engine , I guess with a starting point of about 383 hp I kind of expected close to that. Was not real excited when the tuner said he was able to get 428 hp and 398 tq ? Tuner said with the ambient air temp at 92 to 95 which made the IAT 130+ , these two factors limited the total timing to 22 degrees , which he felt contributed to the lower than expected numbers.
Guess I should also add the Maggie has the stock 3.4 pulley and the blower was fairly consistent at 6.4. to 6.95 lbs of boost. AFR stayed at a fairly consistent 11.4 all the way to 6300rpm.
The cam installed by Lingenfelter is their GT2 cam, although it may not be a perfect blower cam I can't imagine that is a problem.
The car does idle and runs pretty good , kills the tires in 1st gear , and as expected with a Maggie runs as stock during regular driving.
Guess the question is , does this appear to be a tuning problem? Also both dyno's are dynojets. Car currently has 39k miles
FLAFLIER is offline   Reply With Quote
Old 10-21-2009, 07:31 PM   #2
pewter99
Auctioneer Moderator
St. Jude Organizer
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Support Corvetteforum!
pewter99's Avatar
sounds a bit low to me...I put a smaller pulley on my Maggie cranked the boost to 8.5 to get to 460/489...running a small cam (not blower) cam as well
pewter99 is offline   Reply With Quote
Old 10-21-2009, 08:21 PM   #3
FLAFLIER
CF Senior Member
What size pulley did you change to? Before going on the Dyno the tuner said he expected to have to go to a 3.1. or a 3.2 to get near 7lbs of boost, considering I have a cam headers and full exhaust on the car. Was also surprised the engine had near 7 lbs. Do you need to run alky injection for 8.5 lbs of boost ?
Reload this Page Maggie tune question
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Best way to get more power w/ a Maggie... Anthony01 C5 Forced Induction/Nitrous 26 07-13-2005 11:44 PM
Is this the best cam choice??? Jeff @ TPE C5 Tech 19 01-02-2005 07:39 PM
Norris Motorsports / Next Level Performance Stock 2004 Z06 SC Results - 580RWHP Mike@NorrisMotorsports C5 Forced Induction/Nitrous 12 10-08-2004 08:02 AM
Mag top speed? RocketSled C5 Forced Induction/Nitrous 9 09-14-2004 06:01 PM
Head/Cam or Supercharger? Which is less headache? IJustSmile C5 Tech 19 08-31-2004 04:27 PM
Lingenfelter installation? Anthony01 C5 Forced Induction/Nitrous 49 08-25-2004 09:57 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
