Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-21-2009, 07:22 AM   #1
vettezeke
CF Senior Member
vettezeke's Avatar
Default Misfire current cylinder ?? two on # 7
I drove for about 45 min. last night logging the misfire files and ended up with two on the ( misfire current cylinder # 7 ). I got no codes and noticed no missing. Would getting any of these be considered normal or something that needs looked into? I am just getting started with HP Tuners.
vettezeke is offline   Reply With Quote
Old 10-21-2009, 12:39 PM   #2
tblu92
CF Senior Member
tblu92's Avatar
I would check to see if the plug is Ok and the wire--You may get a misfire at idle sometimes or get some bad gas that would make it misfire--so if you say you can't feel it i wouldn't worry--There is a thing as "false misfire"--this is usually caused by adding a stall converter--
tblu92 is offline   Reply With Quote
Reload this Page Misfire current cylinder ?? two on # 7
Tags
7, c4, c5, c6, corvette, current, cylinder, cylinders, hp, hptuners, misfire, misfires, missing, order, scan, tuner
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
what is the latest info about opti-eliminators? SonnyinVA C4 Tech/Performance 10 09-04-2005 01:36 AM
Please Post Secret Codes Again ! ALLEGRO C5 General 51 01-17-2005 12:21 AM
I need urgent help. Andrade108 C5 Tech 18 03-25-2004 05:23 PM
CRAP, I need some help with this one! 212mike C5 Tech 16 08-27-2003 07:35 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
