Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-19-2009, 02:27 PM   #1
tom hatten
CF Member
tom hatten's Avatar
Default jerking during decel
i have 2002 vert about 2weeks ago i put varam cold air intake on ever since then on accoassion i get jerking on decel can be at 40mph or all the way upto 80mph someone told me i needed to go thru process of relearning computer idle so i have done that 2 times still the same anyone else run into this any help much appreciated thanks
tom hatten is offline   Reply With Quote
Old 10-20-2009, 02:32 PM   #2
tblu92
CF Senior Member
tblu92's Avatar
Quite often with a vararam you will get these issues--Are you getting any codes ?--Good news is that it is an easy fix--bad news you'll need a full tuner like HP or EFILIVE---a handheld won't do it--More than likely your fuel trims are way off- Those will have to be corrected----You may need to adjust your "desired airflow" table for In Gear--Adding a % will fix stalling and surging--A fix for a more modded car is to disable or turn off the "DFCO " system----(deceleration fuel cut-off) the jerking you may feel is the fuel cutting on/off-a vararam will alter the MAP #'s and these readings affect the DFCO--
If you have a handheld programmer or a friend does--check your fuel trims while driving and even though your check engine lite may NOT be on--you still may have codes in there--They are called "pending codes" and they could help point you in the right direction---
tblu92 is offline   Reply With Quote
Reload this Page jerking during decel
Tags
c5, corvette, decel, forum, jerking
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
