Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-18-2009, 09:43 PM   #1
redlined
Junior Member
Default A4 Tuning Question
Have a 2001 with some bolt on mods ( long tube headers, high flow cats, Black wing intake, etc) Had the car dyno tuned after the header install, and I am not happy at all with the way the car shifts now. Park to drive or reverse is too hard if the car is not warmed up. 1st-2nd shift is too hard at low RPMs, and very soft at WOT not exactly what I had in mind.
I think what my tuner did was just increase the shift pressure. I have been reading about many other settings like Torque management, RPM setting changes for gear holding and down shifting, and shift duration reductions etc. I think some or all of these settings would get me the results I am looking for, but it's a little confusing to me
It would be great if someone knowledgeable in this area could run down the A4 tuning options and provide me the proper settings to get a nice firm crisp shift at WOT, better down-shift response, better up-shift setting, while still giving me a comfortable shift under normal driving conditions. I would like to get a handle on this so I can have my tuner make the necessary changes.
Any Information or advice would be greatly appreciated
redlined is offline   Reply With Quote
Old 10-21-2009, 12:49 PM   #2
tblu92
CF Senior Member
tblu92's Avatar
I am not a fan of adding line pressure--The shifts will be harsher when the trans is cold--But i never add more than 5-6% accross the Base pressure table only---and never change the tables other than make a global % change--Some people add presssure at lower TQ #'s which make the slow speed shifts bang hard---without knowing what was done one can only speculate as to what was tuned on the trans--
Also subtracting from the "force motor current" table from 0-to about 10 PSI will make it lurch forward when putting it into drive--worse even when cold--there are so many other tables to that create harsh shifting these are the most popular
tblu92 is offline   Reply With Quote
Old 10-21-2009, 04:45 PM   #3
redlined
Junior Member
I am not sure what my tuner did either. What I am going to do is have him put the car back to baseline stock and start over. Which is why I really need the proper settings to give me the desired result, which is a firm crisp shift at WOT especially 1st-2nd, and better down shift responce. Any help from people in the know would be greatly appreciated.
Old 10-21-2009, 05:58 PM   #4
countylawdog
CF Senior Member
countylawdog's Avatar
Call someone who can explain and fix your situation .... just had my C5 A4 tuned by this guy ..... fantastic job.
Chuck @ Corvettes of Westchester 914-332-0049
Mark A.
countylawdog is offline   Reply With Quote
Old 10-22-2009, 09:05 PM   #5
birch64
CF Senior Member
birch64's Avatar
Mark A.
Chuck is the guy great with A4's
birch64 is offline   Reply With Quote
Old 10-23-2009, 06:57 PM   #6
Slowhawk
Premium Supporting Vendor
Best is to contact the tuner and see what they say.
I ussually set mine up alittle firmer at part throttle but the shift gets harder towards WOT.
Slowhawk is offline   Reply With Quote
Reload this Page A4 Tuning Question
Tags
a4, c5, c6, chuck, corvette, crisp, drive, forum, harsh, header, install, predator, shift, slowhawk, tune, tuning
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
0-60 performance for '99 A4 Vert with 3.42 diff and Predator tune berryj C5 Scan & Tune 37 06-16-2004 12:00 AM
99 A4 vert with recent 3.42 rear diff upgrade-can't hardly squeak the tires loose! berryj C5 General 15 06-05-2004 12:55 AM
A4 Guys, question... vettatude C5 Tech 19 03-14-2004 02:03 AM
A4 / 2.73 vs 3.15's JUSTCRZN C5 Tech 29 01-31-2003 10:12 PM
A racer's opinion, M6 vs A4 cars and "Driving" NineBall C5 Tech 87 10-14-2001 11:18 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
