Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-16-2009, 10:45 AM   #1
rwcantrell
Junior Member
Default max energy and 3.42 gears
Okay I've read hypertech sucks. Long story short, I put 3.42 gears in my '98 A4 that already had 3.15 gears in it. Lucky me I get the CEL and code for slipping tranny, 1870 I think it was.
Believe it or not, the car is fast enough for me in it's nearly stock form. The gears and a high flow filter in stock air box is all its got. I don't plan on making any other changes. Just driving it. Don't particularly like the idea of some tuner guy messing with my car, then I can't change it back when I want. I don't want to get a full tuning program and spend hours messing with it either.
Will a Max Energy update enough of the information to keep it from throwing the code? Just wanna make sure before I spend the money.
Thanks in advance. Randy
rwcantrell is offline   Reply With Quote
Old 10-16-2009, 03:37 PM   #2
tblu92
CF Senior Member
tblu92's Avatar
I don't think the max tuner will address any trans slipping codes---with a stock converter you really shouldn't get a P1860 or P1870 code anyway unless you have a real slipping problem---Did you correct the speedo and shift points with the hypertech ? If so this may be your problem---You DO NOT correct a C5 speedo when making a gear change---The speedo sensor is on the output side of the transaxle and not on the input side of the trans like in a camaro/firebird or truck--put the speedo back to stock---You do however need to make a correction for non-stock tire sizes---
tblu92 is offline   Reply With Quote
Old 10-16-2009, 11:49 PM   #3
rwcantrell
Junior Member
I haven't bought the programmer yet. I want to make sure it will change the right information in the computer first. And I read on here that sometimes this issue pops up with 3.15 to 3.42 gear changes, but usually doesn't. Me, I'm just lucky I guess. Car was fine before the swap so I'm positive there is nothing actually wrong with the tranny. Code was thrown less than 5 miles from the dealer after I got off the highway.
Hypertech's website indicates that it will handle gear ratio changes, but the detailed info in their link isn't popping up in their explanation window right.
Wasn't planning on adjusting speedo, thanks for the tip. Seems to shift okay but I'll probably adjust the shift points.
Some discussion here about P1870 code, I think this is my issue as well.
http://forums.corvetteforum.com/c5-g...ing-p1870.html
And here,
http://forums.corvetteforum.com/c5-t...to-3-42-a.html
Thanks!
Old 10-21-2009, 11:25 PM   #4
rwcantrell
Junior Member
Got an email back from Hypertech about the Max Energy, only handles 3.42 gears if you have a manual tranny, doesn't work for autos. Looks like I'll be getting a tuning program at some point.
Old 10-22-2009, 06:40 PM   #5
DOUG @ ECS
Premium Supporting Vendor
DOUG @ ECS's Avatar
Location: Providing the most proven supercharger kits for your C5&C6 609-752-0321
If your interested, I can take care of those issue's with our $149 mail order tune, along with other performance upgrades.
__________________
ECS Sales and Support - www.eastcoastsupercharging.com
ECS Corvette Challenge - www.corvettechallenge.info
www.efiracing.com[/url]
DOUG @ ECS is offline   Reply With Quote
Reload this Page max energy and 3.42 gears
Tags
342, c5, corvette, gears, hypertech, p1870
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C6 Z06 Frequently Asked Questions(FAQ) LTC Z06 C6 Z06 Discussion 56 08-02-2011 03:23 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
